Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
differance between recirculating and circulating?
Old Feb 6, 2010 | 02:49 AM
yahu's Avatar
MAF-less VTA running Speed Density, FTW! I run a TiAL, though. Eric (evil) will run it if it means catching up!
Old Feb 6, 2010 | 07:06 PM
*.jdmevo8.*'s Avatar
lol thanks for the opinions fellas. im gonna keep the recirculating kit on. i just purchased my injen hard piping system from lancershop. might need help putting it on.
Old Feb 6, 2010 | 11:16 PM
RaptorReed's Avatar
Originally Posted by yahu
maf-less vta running speed density, ftw!
+1
Old Feb 6, 2010 | 11:33 PM
D-Mon3y69's Avatar
i've got mine vta and i run perfectly fine. no lag, no stalling, no problems at all
Old Feb 7, 2010 | 01:18 AM
yahu's Avatar
I hear Minh is becoming an expert. This is pretty straight-forward. Just realize if it doesn't feel like you have enough space then you probably don't. Plan to remove obstacles up front instead of cussing at them and removing them later. Make sure you leave clamp bolts accessible from above/below in case you have to adjust later.
Old Feb 8, 2010 | 11:24 PM
03Evo8DTC's Avatar
VTA with speed density sounds SICK lol
im on speed density now and runs great VTA but runing recirc stock works better imo
Old Feb 9, 2010 | 11:55 AM
jdmEviL8's Avatar
^ im wondering what the point of speed density is with 350hp? ...serious question
Old Feb 9, 2010 | 12:14 PM
autoxer_minh's Avatar
If suffering through the process once makes me an expert then ok. I just did the intake but if you need help Rob, I can lend a hand. I second Dan's advice. If it looks like it might get in the way, remove it first. You'll still do some cussing, just a lot less. That upper radiator hose is a prime candidate for removal. Just drain a little bit from the radiator before you do because there is a lot of fluid in that hose.
Wat00756's Avatar
Originally Posted by dbsears
HKS Recirc = vroooooooom pssssshhh CHIRP
HKS nonrecirc = vrooooooom cough pssssh chirp chirp psshh compressor surge
hahahaha lol
Old Feb 9, 2010 | 01:16 PM
thanks minh i will let you know if i need help. would i need a small battery in order for the UICP to fit?
Old Feb 9, 2010 | 02:27 PM
I still have the stock intercooler piping so I don't know how that Injen pipe you have fits. I wouldn't think that you'd need a small battery but if you do I can help you with that. There's a great thread about the Deka small battery and Saikou Michi makes a mount bracket specifically for it. That's what I'm using.
https://www.evolutionm.net/forums/ev...ray-8-9-a.html
https://www.evolutionm.net/forums/ev...tery-60-a.html
Old Feb 9, 2010 | 02:31 PM
does it make any differants with the mini battery besides the the weight and size? i mean i know the weight is alot on big batteries.
evo unknown's Avatar
Stay with a recirculated BOV. The Injen hard pipes will actually increase the loudness of the BOV.
Old Feb 9, 2010 | 02:37 PM
M8NSTER's Avatar
No, Rob. It will fit just fine. I just took out my upper and LICP to put Tclamps on. It was very easy to do by myself. My radiator was out too cause I was installing a new one, but you don't need it to be out. It'll go in with the upper rad hose in.
+ 1 for Dan's comment. Make sure your fittings are easy to get to.
Attached Thumbnails differance between recirculating and circulating?-engine-redone2.jpg
Old Feb 9, 2010 | 02:38 PM
thanks bro. doesnt the injen hard pipe come with the flange thing for the HKS BOV.
