Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Anyone know how to install an alarm system/remote start?
Old Aug 12, 2010 | 10:24 AM
M8NSTER's Avatar
OP- that's not a bad price for all that you get.
This is the one I'll be getting, incase others in the market are checking this thread. I don't think it'll be that hard to install myself, tho I do have a degree in electronics
http://www.zenesisalarms.com/zn302.htm
http://www.maperformance.com/zenesis...-zn-302as.html
Old Aug 12, 2010 | 03:47 PM
drocksmash's Avatar
Looks nice
Old Aug 12, 2010 | 07:36 PM
foam's Avatar
Were you buying that alarm mostly for the auto-start or the alarm function? Sounds like a silly question but I think if you really care about getting a good install on the alarm then you should go to someone professional. That also does not mean Car Toys, Fry's, etc... because those larger chain stores won't really care how they install it in my opinion unless you know someone there.
No place does auto-start on a manual unless you know them because they don't want to be liable for you starting your car and having it continuous drive into your garage. I've heard of stories like that, it happens.
Old Aug 12, 2010 | 08:23 PM
drocksmash's Avatar
Yeah I agree foam, a local forum member gave me the info to a shop that he uses for his evo ... They will install that alarm with all features turbotimer/remotestart/alarm for 220$ and the shop will also do 15% tint for 210.
Seems pretty fair to me, the other chains wanted 250 for the alarm install even if they would do it on a manual.... and realistically i would just like it to be done right, skimping is not really something I want to do on the car.
Also he said in order to do the remote start, you have to install a bypass to make the car think the clutch is engaged, and my dad seems to be convinced that you can start the car in neutral and not depressing the clutch... I will try that when i leave for work tonight, however, I always assumed the clutch needed to be depressed for it to start regardless of the gear.
Thanks for all the posts guys
Old Aug 12, 2010 | 09:06 PM
sblvro's Avatar
I installed the alarm myself and if you know someone professional can get their help in installing it or show you how they install it. because I installed myself, I was able to add some extra features that are extra like perimeter sensor, tilt/motion sensor aside from the shock sensor included in the alarm. there is a trick in not depressing the clutch when you start the vehicle that lets you start the vehicle without the clutch when doing a remote start as well as manually depressing the clutch when you are actually starting the vehicle(like oem). a good alarm system is a starting point, DEI brands or compustar.
jontatt
Sep 9, 2016 06:51 AM
mli604
May 28, 2016 10:19 AM
silverEVO8
Jul 14, 2003 01:24 AM
