Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Need Diagnostic Help!!
Old Aug 15, 2011 | 03:50 PM
jchin1877's Avatar
So I am having problems with the evo and I was wondering if you guys could recommend a shop in the seattle area or even someone on this forum that has some insight on evos that could help me diagnosis these problems. I would go to English Racing but that would mean I would have to take time off work to go down there as well as arrange rides to pick me up and drop me off since I don't know how long it will take and I really can't afford to take time off work right now. Any help would be appreciated.
Old Aug 15, 2011 | 04:16 PM
nemsin's Avatar
Maybe describe your problem. Someone might be able to solve it online.
Old Aug 15, 2011 | 05:22 PM
ILoveAWD's Avatar
what ^^^^^^^^ said
Old Aug 15, 2011 | 06:50 PM
jnut24's Avatar
I could help, I live down in Puyallup if your willing to make the drive?
Old Aug 15, 2011 | 07:18 PM
F0RSAKEN's Avatar
What Jason said... Describe your problem. There are a lot of knowledgable people here.
Old Aug 15, 2011 | 07:33 PM
jchin1877's Avatar
The main problem is every time I shift my rpm spikes as soon as I step in the clutch. It well shooting anywhere between 300-600 depending on hard I am on throttle before shifting. So for example if I'm at wot it will spike like 600 rpm when I shift
Old Aug 15, 2011 | 07:35 PM
jchin1877's Avatar
My mods are greddy ti-c turbo back exhaust, hks rs intake, ets lower intercooler pipe, halloman mbc, and a tune by English racing
dscevo8's Avatar
My bad...didn't read that it happens when the clutch was engaged
Old Aug 15, 2011 | 08:09 PM
nemsin's Avatar
Sounds like its time for an OEM replacement from mitsubishiparts.net or ACT clutch upgrade from MAP.
Old Aug 15, 2011 | 08:54 PM
anthonyrb98's Avatar
slippage sucks
Old Aug 16, 2011 | 09:42 AM
Ryan.Kauz's Avatar
Originally Posted by dscevo8
You my friend have a slipping clutch. I would save up and prepare to take the car down to English
Could be the lower intercooler piping.....
JK, check out this thread for what people are running:
https://www.evolutionm.net/forums/no...o-you-run.html
Old Aug 16, 2011 | 01:41 PM
jchin1877's Avatar
Damn alright thanks guys
Old Aug 16, 2011 | 04:22 PM
F0RSAKEN's Avatar
Whaaaaaat.... Did any of you actually read what he wrote for symptoms? It sounds like the typical Evo over-rev that a lot of cars are plagued with. My RR had it, and quite a few others have as well. If it is your problem, ER can most likely tune it out.
Just for everyone else, typically a slipping clutch can't be felt when you disengage (push pedal in) it. Didn't really think that had to be stated, but wtfe....
Old Aug 16, 2011 | 08:01 PM
ILoveAWD's Avatar
i agree this is not a slipping clutch a slipping clutch would be felt when he hits the gas thais is just over rev. i have the same problem and my clutch is brand new less than 2000 miles on it. after doing some research of my own i noticed that alot of evo's have this problem.
Old Aug 16, 2011 | 08:12 PM
JohnBradley's Avatar
Like Andrew said.
Sounds like throttle hang. We can fix that normally. If it revs up in gear then we are talking about a slipping clutch.
