UPDATED---Shiv from Vishnu coming to PDX
Sorry to have to inform you guys, but unfortunately a family emergency came up in Shiv's household and the day have been postponed. I am still waiting to hear back how soon he can come up here.
From the sounds of it for most guys this means more time to mod. For those who took work off to make it down, on behalf of Vishnu, I apologize for any inconvenience this may have caused.
Shiv will still be coming up and he'll still be wringing lots of power out of your beast.
TTYS,
Jeremy
TTYS,
Jeremy
Thanks Jeremy. We ran out of time and will be back soon. We realize it needs to be leaned out and timing adjusted. The torque curve looks like it needs help in the lower end, so some more work to do for sure. I can't wait!
I need some lower end work to, if you know what i mean
Should I get some 660's with my stage 1+???
Man I hope i can get some #'s like that. What are your cam sprockets set to?
hey... cam gears set to -3 retard. The bigger injectors eliminate the maf overflow (boost cut) but you can get the flash to take care of that for cheaper. The only other reason to get bigger injectors is if your going to be maxing them out. With a stock turbo I think the IDC's are fine from what I hear. So you won't need to goto 660's unless your thinking about a bigger turbo. Personally I wanted to upgrade my fuel system so I had no worries about plenty of fuel and a bigger turbo will be in the works.
Eric Lyublinsky
Northeast Region
10
Jan 12, 2004 07:39 AM
doc_evo
Northeast Region
80
Oct 24, 2003 01:59 PM
