evo trunk and APR wing FS
Old Sep 1, 2012 | 04:21 PM
nothere's Avatar
sellig my evo trunk that has an APR wing installed on it. Early series (2003) white.
$600
Old Sep 1, 2012 | 04:23 PM
nothere's Avatar
add
Old Sep 1, 2012 | 04:53 PM
fcapistran's Avatar
I am interested on the apr wing.pm me for the price if you wanna split.thank you.
Old Sep 1, 2012 | 07:35 PM
nothere's Avatar
I'd rather sell them together. The APR mounting holes are exposed if you go to the stock wing.
Old Sep 1, 2012 | 08:14 PM
fcapistran's Avatar
hit me up if you change your mind.the sooner the better.
Old Sep 1, 2012 | 08:43 PM
codgi's Avatar
Is that a mounting hole exposed on the right side of the 2nd pic?
Old Sep 2, 2012 | 07:38 AM
nothere's Avatar
that is the stock wing hole, with a plastic cap on it. you also see a strip of the original two sided tape that I never removed.
Old Sep 2, 2012 | 10:16 AM
codgi's Avatar
I see. Thanks
Old Sep 2, 2012 | 05:14 PM
nothere's Avatar
here is a photo of the mounting holes. The hole towards the front of the car is the APR extra. The black circle is OEM tape over a hole intended for future wiring? This is the black circle you see in the picture some frames up.
The front APR hole is outside the base of the OEM wing. The APR wing base holes are further apart than the stock. So it is necessary to use the rear stock hole and create a hole forward. This still leaves the OEM wire hole exposed. If you use the front stock hole it moves the APR to far rearward.
Old Sep 3, 2012 | 10:09 AM
codgi's Avatar
Thanks! YGPM!
elkazX
Aug 4, 2014 03:44 PM
plan:b
Apr 20, 2014 01:20 PM
Fawkz
Feb 15, 2014 02:13 PM
