Front Strut Towers : OEM Brace "ring" - Deleted/Missing, why?
Old Jan 17, 2013 | 01:31 PM
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
I noticed that these metal brace"ring"s are missing on my 2013 Outlander Sports vs. 2012 models..
2012 (you can see the black metal "ring" bolted down to the top of the strut towers)
2013 (they are missing)
Close-up Driver side
Close-up Passenger side
Does anyone know why?
Did Mitsubishi strengthened the strut towers either with thicker/stronger steel or may have left these off just to save a buck?
(I'm not referring to a "strut bar" but more like a "ring" bolted down over each of the strut towers, individually from each other.)
Should I worry?? Does anyone know if Mitsubishi strut towers are areas of concern - from "mushrooming"? The reason why I ask is some of our roads/streets have a fair amount of potholes and I don't want to risk deforming if I can help it.
Should I re-enforce the towers with an aftermarket strut bar... or stick with factory brace "rings"?
Thanks
Old Jan 17, 2013 | 01:45 PM
Ugleeboi's Avatar
i have no clue.. I have a 2011 I wonder if i have that ring.
Old Jan 17, 2013 | 11:55 PM
Burtonrider1002's Avatar
EvoM Moderator
I wonder if you have different shocks as well...
Old Jan 18, 2013 | 07:37 AM
mRVRsport's Avatar
Hmm.. I think I did read somewhere online that the 2013 did get some suspension tweaks.. but it wasn't detailed on what was done/had changed from previous models.
Old Jan 24, 2013 | 12:05 AM
fujing21's Avatar
2013 has a stiffer rear suspension
Old Jan 24, 2013 | 08:07 AM
mRVRsport's Avatar
Hmm... is that right?
Do you mean the subframe-bushings, control arm bushings, or stiffer shocks? More details?? Link to info??
Old Jan 24, 2013 | 09:54 AM
tdott's Avatar
Makes sense I always found the rear too soft.
My thoughts were to try to get stiffer and taller rear springs, but haven't really bother to figure how or where to get some from. The first place I thought of checking was to see if the outlander had the same spring design and how that they were taller and stiffer.
Old Jan 24, 2013 | 10:03 AM
fujing21's Avatar
Wish I can find a stronger anti-roll bar for this model. body roll is still too much....
Old Jan 24, 2013 | 10:04 AM
fujing21's Avatar
Don't know, I guess a different rear spring, nothing major.
mRVRsport
Outlander Sport
36
Sep 12, 2018 06:45 AM
mRVRsport
Outlander Sport
26
Nov 2, 2017 09:53 AM
FastGST
Outlander Sport
13
Feb 15, 2016 02:52 PM
87BlackStar
10
Dec 31, 2015 11:19 AM
mRVRsport
Outlander Sport
10
Sep 18, 2015 01:05 PM
