Power Steering Concerns
Old Nov 21, 2013 | 05:21 PM
Burtonrider1002's Avatar
EvoM Moderator
So we have electronic power steering as opposed to the standard hydraulic assisted setup (or w/e it's called).
Normally, when you lose a serpentine belt, you just lose the POWER steering, but still have manual control of the vehicle.
What happens if we lose all power? Is there still a manual connection?
Old Nov 21, 2013 | 06:02 PM
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
Good question.
(I don't have detail schematics of our steering rack.)
But, I do believe we have direct drive to the steering knuckles. It's part of the fail-safe mechanism, the way I'd imagine if I design it.
The way I test to confirm this is simple -
1. Active your Accessories (No need to start the engine)
2. Move the shifter out of Park into Neutral.
> You are able to turn your steering wheel and the wheels respond accordingly.
(This simulates the event of "losing" all power from the engine & alternator & [del]battery[/del]..)
Old Nov 21, 2013 | 10:32 PM
RA012124's Avatar
Or go 10mph in a parking lot, turn your engine off and try to steer.
Old Nov 22, 2013 | 12:51 PM
mRVRsport's Avatar
Can you do that?
Will the Start/Stop button work when the vehicle is still in motion (not set in Park)??
Old Nov 22, 2013 | 12:58 PM
EvoM Moderator
Originally Posted by mRVRsport
Can you do that?
Yes, I know that for a fact. I don't remember why, but I did shut it off one day. I was going straight, so I can't comment on the power steering.
Old Nov 23, 2013 | 07:07 AM
BTBean's Avatar
I havent tried it in the OSport, but my Veloster had push button and it was like a car jacking feature. You had to hold the oush button for a few seconds in motion to shut it off, that way you couldnt accidentally hit it while driving. Should work the same with the O Sport. Then you run away woth the key amd the would-be jacker is stranded and Blue Link tells you right where your car is. Hyundai didnt advertise it that way, but my counter-terrorism side of my brain saw it that way.
Old Nov 24, 2013 | 12:42 PM
mRVRsport's Avatar
Okay.
Logical.
Say...what?
Live4Redline
27
Apr 14, 2018 04:13 PM
asu11
Feb 18, 2017 11:13 AM
Evo_Goodness
Jan 24, 2017 06:54 AM
araz5260
Jun 24, 2016 03:50 PM
Go_Lancer_Go
Jul 13, 2009 08:59 PM
