Dash Vents
Old Oct 20, 2014 | 11:25 AM
jwark16's Avatar
Dash Vents
Hey does anyone know how to get the front dash vents off? We had a little incident on the weekend and some "foreign matter" may have gotten into the vent itself. So I'd like to take the front of the vent off to make sure its all clean.
Old Oct 21, 2014 | 05:40 AM
TEXAS TRAVISTY's Avatar
best to use the right plastic dash removal tools buy a very small flat head seems to work as well, gentle apply pressure around the seem using leverage against the dash itself and the vent should pry forward so you can pull it out, it will be held in with plastic pressure clips on the side so be careful not to break any of the plastic light pressure do not try and force anything or you will end up with a vent that will not seat back into place, there should be a you tube instructional if you need a visual as well.
hope this help a bit
as far as the center vents just do the same thing from the bottom of the cent radio bezel, gently apply pressure using leverage on the bottom of the center dash bezel in three places, far right, middle, and far left bottom down by the HAVAC control (or the 3 AC control knobs).
the dash will pull up and pop out for you so you can clean it as well.
saulbyu
Evo X How Tos / Installations
15
Feb 19, 2015 08:11 PM
jcdeng
18
Nov 8, 2009 11:04 AM
skylinegtr35
Sep 13, 2009 09:59 AM
04ozrally
Jul 20, 2006 11:09 AM
