AWD modes
These time I was behind the camera
I am not sure about the throttle, it looks more sudden, but this is automatic version, while my ASX is manual. Throttle increase is also dependent on which mode is selected (in Sport it starts much faster than in Snow). I think it just starts like that when there is no friction under some wheels.
Generally traction control seems to be faster - I also tested older Grand Vitara AT, same driver, it took more time to get out of the rollers, but still less than ASX needs.
Front/rear torque distribution is similar, however in Lock mode Mitsubishi works far better.
I bought a 2014 OS for my daughter and great car with exception of rapid acceleration i.e. getting on highway. Auto 4wd drive seems to be most responsive but I can only describe the automatic shifting as "wonky". Are there any non-exotic tweaks to improve? Different transmission fluid? Non-warranty breaking mods?
2.0L or 2.4L?
2.0 - Sorry, I responded from phone immediately but appears it didn't post
Again, it's my teenage daughter's car so not looking to drop in new cat back exhaust or anything like that. I would just feel better if acceleration was better when getting on highways. It just seems to "bog down" when you try to quickly get up to highway speed. Seems like engine is over-revving and not accelerating as efficiently as possible. So to me seems more like a CVT issue than a horsepower issue?
maybe have the dealer give the TCU a scan if its still under warranty?
That's a great idea being specific on having them look at TCU - thanks! The only way this car would "chirp the tires" is if I stripped it bare and filled with Racing gas!
its weird, i always have performance cars (Evo MR, G37 coupe, just sold a Porsche 928), and i have to remember to go easy on my wife's OS from a redlight.
one time i said, "**** it, i'm going to step on it and see what happens ... " the torque steer damn near ripped the steering wheel from my hands.
i guess it wouldn't do that in AWD mode, but its in FWD 99% of the time.
Considering a hybrid AWD SUV and need solid AWD performance? No
Here is an interesting test on the capabilities of the Toyota RAV4 hybrid and Outlander PHEV.
It is disappointing how poor torque appropriation these vehicles can do:
For comparison the same tests performed on the AWC and S-AWC regular Outlanders:
You'll be the judge.
Unfortunately, the reported split of the torque varies quite a bit depending on the source. As mentioned in the source Landshark quoted above one report assumes 15-40% (4WD Auto) and 15-60% (in 4WD Lock) torque to be sent to the rear axle, while Mitsubishi's own Powerpoint presentation (see the relevant attached images) assumes up to 70% of power to be distributed to the rear wheels. (Note the dubious language: power and torque are not the same quantities). Since the power vs. rpm curve is steeper than the torque vs rpm curve (from zero to peak) it can make a huge difference whether the awd system regulates at low or high rpm.
To make things even more complicated the video below (for Citroen C4 Aircross that uses the same awc system as OS/RVR reports a much wider range of torque distribution:
https://www.youtube.com/watch?v=-68Zmhv3Kgs
In 4WD Auto (go to 2:33) 2-50% to the rear, while in 4WD lock( go to 2:47) 2-70% is assumed to be sent to the rear.
It is absolutely certain that some torque is always sent to the rear. That is why the fuel economy figures are different in different modes. Had we have a "slip-and-grip" system there would be no need for manual selection option (the electronics would take care of the torque distribution within the programmed limitation). We have an option to prioritize between fuel economy, traction and wear and tear. I think it is awesome.
The OS (and the French clones) has a simpler AWC system, your Outlander GT and the Eclipse Cross come with an updated S-AWC system that is tuned for fuel economy (that is why the introduction of the AWC Eco mode). I am almost sure that the new mode designations are just different programming features. Component-wise the S-AWC system has an active front differential, while the AWC does lack of it.
Hybrid 4x4 roller test
Outlander GT S-AWC vs Outlander 2.0 AWC roller test
weird that they are constantly changing the "mode names".
i kinda like the fact that the OS can just be set FWD - as 99% of the time, you don't really need the AWD, at least for the mild winter we had so far.
my Evo had "TARMAC/GRAVEL/SNOW" modes, but my mom's Eclipse Cross has "AUTO/SNOW/GRAVEL" modes. EC uses the brakes to torque vector, where the Evo had an active center differential.
I agree that the names are confusing and perhaps the new ones refer to the influence of software involvement rather than changes of hardware. They should have come up with different names for the EVO and the Outlander as they are quite different.
To begin with "AWD lock mode" is a misnomer itself as there is no locking differential in the OS. As an end user I am not really concerned about the names and the PR behind it though it would be nice to have some connection with reality of the actual mechanism. I would like to have, however, a potent AWD system that can cope with the amount of snow we get in my area ( we just received another foot of blessing yesterday). I am still hesitant about the effectiveness of the PHEV pure electric AWD system although I was happy to discover some improvement.
elecan
Evo X How Tos / Installations
Sep 28, 2015 11:52 PM
mRVRsport
Outlander Sport
Feb 21, 2013 05:12 PM
mikespike2
16
May 14, 2007 09:45 AM
