camber correction?
Old Aug 12, 2015 | 12:48 PM
TEXAS TRAVISTY's Avatar
camber correction?
does the outlander sport have adjustable rear camber bolts?
Anyone lowered using some sort of rear camber correction?
Just wondering, what brands, or companies. Or have any links to a camber correction kits?
Old Aug 12, 2015 | 01:06 PM
http://www.moogproblemsolver.com/_pd...100114_Eng.pdf
I found this, for around $106.00.
I am trying to find some +- 2.75 camber bolts though.
Old Aug 12, 2015 | 02:47 PM
Nast_Nas's Avatar
theres also SPC, Megan, Hardrace, and realtuned(originally for Caliber but will also fit). These are all upper control arms! All the others are listed under either lancer or outlander sport. There are no (bolts) that will get you with that adjustment unless it's more natural camber, whiteline has rear bushings replacements, they don't replace the whole arm.
Old Aug 14, 2015 | 05:49 AM
awesome thanks so much for the info that helps a lot
Old Aug 23, 2015 | 07:42 AM
Hiboost's Avatar
So how much negative camber is gained when you lower these cars say an 1"?
Old Aug 24, 2015 | 05:39 AM
I don't know but mine is now barely 4" off the ground so the drop is significant. I went ahead and picked up the moog rear adjustable lateral arms, they are super beefy and have a correction of -+2 degrees, so that should be plenty to save the rear tires for crazy wear.
SLVROZ_03
Aug 15, 2007 02:07 PM
JWERNER24
Oct 5, 2005 05:18 PM
deuxforever13
22
Jun 24, 2004 07:16 PM
1/3Evo
Dec 4, 2002 03:39 AM
