running wire through firewall on outlander sport
Old Sep 11, 2017 | 01:58 PM
xelloss's Avatar
I'm going to install an inverter in the cabin and am going to run 2 power cables from the battery. But I'm unable to find a spot that allows me to pull 2, 8-gauge wires through. I looked at the main wiring grommet, there was no way to fit 2 8-gauges through that hole. I didn't want to poke a hole there....
I've looked at another forum that said if it's a Lancer, there is a small grommet somewhere around the lower left of the engine bay which allows wires to come out from underneath the glove box. I wonder if the Outlander Sport has the same grommet.
Any help would be appreciated !!!
Old Sep 11, 2017 | 02:37 PM
AWCAWD's Avatar
My method is found at post #869 in this thread:
https://www.evolutionm.net/forums/ou...-today-58.html
Old Sep 11, 2017 | 03:37 PM
xelloss's Avatar
NICE! So it does have the similar grommet somewhere there.
Thanks for the help!
Old Sep 11, 2017 | 05:05 PM
AWCAWD's Avatar
I am happy to help if I can. It is not a grommet but rather a rectangular (with rounded corners) cover with foam sealing. You should be able to fish your cables (vertically) across. This is why a coat hanger is a great tool for this job. With this method you will need longer wires though but no drilling is required. Good luck.
Old Sep 12, 2017 | 09:15 AM
xelloss's Avatar
So I've tried to look for that rectangular shape opening as AWCAWD described last night. I looked from behind the glove box as well as from the engine bay, but I had no luck finding it. I did peep behind those lining by pulling them down a bit but I didn't pull them all out. Is that hole way under those engine bay linings? If anyone could show a picture with some pointers or just circle the area where I should be looking at, that would be greatly appreciated !!!
Thanks for the help..
Old Sep 12, 2017 | 09:40 AM
AWCAWD's Avatar
This opening is not visible, so looking and peeping will not help.
You have to remove the plastic gutter underneath the windshield (outside)and reach into the opened space under the windshield until you get to the vertical metal sheet (firewall). Then move your finger until you feel the mentioned opening with a foam insulation. It is tight. You will be able to pull the wire in from inside after removing the glove box and reaching up to the upper corner just under the windshield.
For reference I insert my description again from post #869
"I found a spot above the glove box on the passenger side that can be accessed by removing the glove box (inside) and the plastic gutter below the front wipers (outside; coat hanger is needed again). "
Attached Thumbnails running wire through firewall on outlander sport-wire_passing_location.jpg
Old Sep 12, 2017 | 11:31 PM
xelloss's Avatar
thank you for the tips and the diagram! I'm gonna go knock myself out again. Cheers.
Old Sep 13, 2017 | 01:20 AM
xelloss's Avatar
Hi AWCWD...
Did you mean to run the wires thru this big hole? This is an air duct or something and there is no space to pull any wire thru it.... I'm kinda confused.... :\
Old Sep 13, 2017 | 06:40 AM
AWCAWD's Avatar
Yes. Just reach in and up and you will be able to feel a foam isolated piece. I am attaching three diagrams from the body repair manual. I pulled two wires through this although it is tight as I explained.
Attached Thumbnails running wire through firewall on outlander sport-upper_firewall.jpg   running wire through firewall on outlander sport-upper_firewall2.jpg   running wire through firewall on outlander sport-upper_firewall3.jpg
Last edited by AWCAWD; Sep 13, 2017 at 06:54 AM. Reason: updated with added diagrams
Old Sep 13, 2017 | 02:09 PM
xelloss's Avatar
Thanks. I will take a good look again. On the other hand, however, I'm also trying to feed the power cables from behind the fender to the cabin. Since running the cables all the way from the battery, through that air duct and go back into the cabin, the cables will be quite long (which lead to greater lost in power). If it's possible to feed them through behind the driver side fender, that would be a significantly shorter route.
Old Sep 14, 2017 | 07:55 AM
AWCAWD's Avatar
I understand and looking forward to seeing your solution.
I would be more concerned about the cost of the wire than the loss of power. If my quick calculation is correct, with your 8 gauge copper wire (cross sectional area and specific resistance are available on the web) you would lose a little over 1% more power with 4 m of wire than with 2 m provided you want to draw 30 A current. In other words you would need more than 8 m wire to see 0.5 V drop in voltage at 30 A load. I assume you will not draw 30 A unless you plan to use a hair dryer with the inverter. How critical is the stability of voltage for your proposed application?
Just a reminder: in a modern car we have something like 1 mile long cables total, whereas in a Boeing 747 about 170 miles.
Old Sep 14, 2017 | 08:28 AM
xelloss's Avatar
Tried to take off the drive side fender, but nope! couldn't do it... I was too chicken doing it LOL. I'm no autobody shop guy, I don't wanna break the panel or crack the paint by pulling it it out by force. I'm gonna seek for help on that...
Nah, I'm not planning to plug any power thirsty tool like a 1600W hair dryer there...LOL. But since the inverter has 300W output, I just wanna maximize it in case I need it.
Old Sep 14, 2017 | 08:38 AM
AWCAWD's Avatar
My calculation was for 360 W (nominal).
Old Apr 10, 2018 | 01:17 PM
itziklevy86's Avatar
Front parking camera installation
Nimpoc
Sep 14, 2012 08:58 AM
zipperhead
17
Feb 15, 2009 04:21 PM
BARNSEY
Aug 27, 2007 11:15 AM
BARNSEY
Aug 27, 2007 03:36 AM
ralliart99VR4
Aug 8, 2004 08:27 PM
