3rd gen Os compatible parts
I’m looking to have everyone stock pile the compatible parts between the evo x, and the ralliart that can be directly swapped to the outlander sport.
from information I’ve gathered so far, you can use the evo x cams, cam gears, suspension but I’m looking for more in depth parts
can you adapt the gsr and ditch the cvt and if so what kind of tuning will need to be done if you have information based solely for performance I’d like see everyone gather that info in one spot.
With larger diameter tires that lower ratio 1st gear ratio of 3.538 won't be fun.
Here are my ratios:Transmission Model: F5MBB
Engine Model: 4B11
Transmission Type: 5 speed, floor shift
1st: 3.833
2nd: 1.913
3rd: 1.333
4th: 1.028
5th: 0.82
Reverse: 3.583
Final Drive Ratio: 4.235
Believe me even 3.833's for first isn't low enough. Since the 4B11 has basically zero torque in the lower rpm range and twitchy throttle response it is a nuance to keep the rpm's between 500-1000 rpm as you engage. A toe's worth of extra throttle input will send your rpm's to1500-2000 rpm in a instant. I've been driving manual transmissions all my life and I'm 60 now but I will say that this combo would not be for a beginner learning to drive a manual. You'd smoke the clutch in no time.
Engine Model: 4B11
1st: 3.833
2nd: 1.913
3rd: 1.333
4th: 1.028
5th: 0.82
Reverse: 3.583
I have thought about importing the 6spd manual for the diesel OS in the UK. The gearing is close 1-3 but the 4-6 is all much lower and the 4j11 doesn't have diesel torque. Maybe after adding turbo. Plus can't find any info on the Bell housing bolt pattern.. To know if it's even possible. Wish they would done a 6spd the bean counting bastards!
Transmission Model:- F6MBC
Engine Model:- 4B40
Transmission Type:- 6speed, floor shift.
Transmission gear ratio
1st 3.833
2nd 2.047
3rd 1.303
4th 0.975
5th 0.744
6th 0.659
Reverse 3.545
Final reduction ratio 4.058.
I've seen a few of these available in the UK running about $750-$1000 USD. Shipping would probably double the price.
Engine Model:- 4B40
1st 3.833
2nd 2.047
3rd 1.303
4th 0.975
5th 0.744
6th 0.659
Reverse 3.545
It should bolt up since the 4B40 is just a successor to the 4B11 2.0 and the 4B12 2.4 found in our OS'. 4B40 is the engine in the Eclipse Cross. That transmission just isn't available in the North American market. But you'd have to check with a transmission shop. I got the ratio and transmission model info from a Eclipse Cross forum I follow and looked up the info on a European parts site to confirm . The downside is that there have been some 1st to 2nd synchro issues with this transmission with a few members having serious issues. My 5 speed also needs to warm up extensively 30+ minutes of driving before it gets buttery smooth. When it's cold or even cool, it's a notchy beast and I never ever speed shift it. I replaced the gear oil at 30k with Redline and it helped but cold temps are not your friend. When I drained the OEM fluid @30k it looked fine, no metal shavings or particles at all. Fluid looked clean. I have 41k on the clock now and it shifts awesome (better with Redline) but I take extreme caution until it warms up.
