Pacific Northwest General areas surrounding Bellingham, Seattle, Tacoma, Bellevue, Spokane, Yakima, Portland, Eugene, Bend, Medford
60k service...
Old Sep 30, 2012 | 08:29 PM
Sloppy Hachi's Avatar
60k service...
It's getting to be that time for me and I was wondering if some seasoned veterans on here could give me an idea of what all I need. I've seen various 60k service kits from mitsuparts and lancer shop, etc, but none of them really hone in on EVERYTHING that is listed in the service manual. With that being said, here's what I've done recently:
New plugs
New trans fluid
Front diff fluid
Oil change
I have coolant, I know I need the belts but can someone help specify on what exactly needs to happen here? I've used the search bar and haven't really found anything that answers my questions. If someone finds a thread and can direct me to it that would be greatly appreciated otherwise I'm looking for answers to what all I need and if there's any tips, hints, or tricks that will help while I'm performing this maintenance. Thanks fellas!
Old Sep 30, 2012 | 10:37 PM
03Evo8DTC's Avatar
http://www.evotuners.net/forums/f2/60k-service-2351/
https://www.mitsubishicars.com/media...dule_Turbo.pdf
Old Sep 30, 2012 | 10:47 PM
RaptorReed's Avatar
The fun part of the 60k Service lol and most expensive.
Timing Belt
Balance Belt
Tensioner
Tensioner Pulley
Balancer Pulley
Water Pump
Water pump gasket and O-ring
Old Oct 3, 2012 | 08:57 AM
OfaceGrimmins's Avatar
Timing Belt
Balance Belt
Tensioner
Tensioner Pulley
Balancer Pulley
Water Pump
I'm at 108k right now, didn't do my water pump with the tbelt @ 60. Changed my tstat at 90k along with the clutch (again) and haven't had a single drip from the wp. Weird. I'll be doing it for sure at my 120k though. Mitsu WIN.
Old Oct 3, 2012 | 09:13 AM
Dallas J's Avatar
Veteran: Army
With how expensive the water pump is for an IX I would wait until it went out or 120k to do it (assuming you do all the work youself, then its just time) but with the VIII the gates pump is cheap enough to just do while you're in there.
Old Oct 5, 2012 | 12:34 PM
js06evoix's Avatar
I'm with you Owen, I didn't do my WP at 60k either (my buddy who works for Mitsu suggested against it) and haven't had a single problem. Haven't replaced my Tstat either.
My 60k I changed the plugs, did the timing belt and accessory belts, tranny fluid, transfer case fluid and rear diff fluid, coolant flush and fuel injector service. Still runs perfectly fine and doesn't leak anything.
Old Oct 5, 2012 | 04:12 PM
Thanks for the feed back guys, I really appreciate it!
Old Oct 5, 2012 | 09:10 PM
jnut24's Avatar
or you can have david @ boss innovations do it for you?!?!?
Old Oct 5, 2012 | 09:26 PM
No homo but I'm developing an intimate relationship with my Evo and aside from tuning I plan on doing the majority of all the work myself.
Old Oct 8, 2012 | 05:16 PM
Cars are girls bro Mine is anyway hehe. I get up under her skirt all the time!
Old Oct 8, 2012 | 06:35 PM
js06evoix's Avatar
Well now I know when I see an Evo on the side of the road.. who's car it is! It'll be one of the two of you! LOL
Old Oct 9, 2012 | 07:19 AM
You just wait! lol I plan on documenting everything and hopefully posting a thorough "How-To" to help the next noob like myself.
Old Oct 9, 2012 | 11:53 AM
Are you implying sudden mechanical breakdown? Or constant skirt lifting?
Old Nov 27, 2012 | 11:46 AM
ancker's Avatar
Just called around for 60k quotes.
Dealership: ~1500
Local Shop: ~1900
Wish I had the tools/knowhow to do the work myself.
Old Nov 27, 2012 | 12:11 PM
SleepySamurai13's Avatar
please do, is the 60k service possible to do without pulling the motor? i want to do mine myself but it seems a little intimidating because of the balance shaft/ pulley/ belt. seems easy to screw something up. this is the one service ive been nervous to perform myself.
