Josh,
How long have the valvesprings been in the car? Could they be losing spring rate overtime? Are you running Kiggly's? |
Originally Posted by TwStDeVo
(Post 9648925)
honestly man, i think its the twinscroll set up. all the cars with singlescroll kits made crazy power and held all the way. id be willing to bet that if you swapped to singlescroll it would solve your issue.
Originally Posted by R/TErnie
(Post 9648959)
Josh,
How long have the valvesprings been in the car? Could they be losing spring rate overtime? Are you running Kiggly's? It has the standard springs that come with the BR Stage III head. So whatever come with them is what I've had on there for a while. I got the head in Feb 2009. What I can tell you is that my sweet driving skills has made the car rap put and bounce off the rev limiter a few times so maybe it damaged them then. Again this is due to my awesome (see crappy) driving skills. |
Originally Posted by n2oiroc
(Post 9648980)
i was going to say, that turbine housing sounds kinda small. maybe the 1.15 would be a better choice.
I've been told (if you look here #23 https://www.evolutionm.net/forums/ev...o-sheet-2.html) that smaller one would be better. I am hitting like 6000-62000 full boost so putting the 1.15 would move that to around 9000 rpms... |
Josh, I hope you find the solution. I'd start with the larger housing.
Meanwhile, that's not a bad problem to have -- power falling off at 720 HP :) |
Originally Posted by CO_VR4
(Post 9649065)
Yeah Josh. Why can't you just be happy with 720whp. Really... :D
I was wondering why your car was there when we were tuning mine on E98. |
whats the boost doing when the power is dropping?
(Post 9649108)
I had a similar problem with my 4088 and changed the housing to a larger one. Added more fuel. Did this, did that. Cost me a ton of money and ya know what it was..old turbo technology and I maxed the 4088 out at 674 HP. As soon as we bolted the 3794HTA on it shot straight up (HP wise that is) to where we are at now on the first pull. |
Originally Posted by rodent
(Post 9649107)
I'd throw a new set of Kiggly's at it for a cheap test.
After that I'd try a BW EFR 9180 :) with the big T4 TS hsg. |
Sounds like a possible valve float issue to me.
Aaron |
720whp corrected or uncorrected, Mustang or DJ, and you can see valve float in the dyno sheet in the event you cant hear it. I just recieved a 1.15 this morning and it doesnt look that big ;)
Aaron |
(Post 9648925)
Aaron |
Originally Posted by JohnBradley
(Post 9649229)
Aaron |
