Ok, i'm at work right now so I can't check and see. The big white and black connectors you're talking about, which ones are they? So looking at the big bracket with the 4 connectors which ones are they? Top? Bottom? Left? Right?
They are the two against the wall on the left they are on top of each other. I wanna say the black connector is on top of the big white one but not 100%. The black one has like three wires goint to it the white has alot. I soldered every single wire in every single connector just to be safe. Plus I sealed the grommet up for good
subscribed. I need to take care of all these leaks this weekend now before they actually turn into a problem. I swear, I'm seriously disappointed in sucksubishi's build quality. Why the HELL can't Honda make a comparable AWD turbo rally car? If they did.... :banghead: I think I just need to cool down. This is just disappointing.
my f-ing horn is going off. removed the fuse to make it stop but i guess this is my g-damn problem. FAAAAAkkkkk. ok i need to calm down...
sub
Sounds like it's related to this. Has this link been posted yet?
https://www.evolutionm.net/forums/in...s-how-fix.html |
That's usually the issue if you have problems with wipers, starter, headlights or horn. Check your connectors in the kick panel.
Up.
Sounds like this area is one I need to address. Droving into work today, no rain, 39*, and the wipers suddenly came on and would not go off, even after I turned the car off at an intersection. I garage my Evo so I'm not in constant rain, but I'd imagine this is the area I need to address, the wiring behind the kick panel? |
Originally Posted by True Blue
(Post 10605505)
Up.
