-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Winter Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-winter-projects.html)
LV///R Sep 12, 2023 04:44 PM
Originally Posted by ViciousLSD (Post 11972416)
Again, I dont understand why you can do amazing launches and dont break stuff
I'm knocking on wood as we speak. I've only used the ACT HD street disc in all 3 evos. I gotta be north of 500+ launches by now and never an issue with the trans/diffs.
ViciousLSD Sep 12, 2023 06:08 PM
knocking on wood with ya. After this I've replaced everything in the past year except axles, driveshaft, belt accessories, acd pump. oh what could be next...
ViciousLSD Sep 13, 2023 07:27 AM
Originally Posted by CaptainSquirts (Post 11972423)
It took me like 4 years of launching at autocross at 340 to the wheels(dyno’d 12 years ago) for my first gear to break some teeth while in stop and go traffic. The trick for longevity is to toast the clutch when you launch 🤡.
What exactly is this sound? DId you have the same when you broke 1st gear? I posted about seeing metal bits several months ago when I did my clutch. that should have been the telltale sign its on borrowed time
CaptainSquirts Sep 13, 2023 08:32 AM
I never took a video of it but when it broke(a tooth) i had like a very little jerk in the car and a slight clunk. Afterwards while driving I heard what almost sounded like a couple of rocks making rattling noises. Yours is a more consistent noise while mine was almost like 3 pebbles being shaken around in a can. My first gear and final drive had a couple teeth missing. I have the invoice of all the things that were replaced. It was def more than what I was expecting in terms of things that were recommended to have replaced.
This is what mine showed on the drain bolt when it happened.
http://dagroj.com/download/file.php?id=1488&mode=view
CaptainSquirts Sep 13, 2023 08:40 AM
1 Attachment(s)
Ahhhh I found the picture that Aaron from TRE posted on instagram from my gears.
Bee-Raddd Sep 13, 2023 11:12 AM
Im touching every piece of wood i can find right now but ive never blown a diff or gear component from launching. thats with 700hp. Warm slicks. Twin plate clutch.
I think alot of it comes down to how you launch. If you just side step the clutch and hope for the best then of course things are going to break. Needs to be a smooth initial transition and then use the clutch to adjust how much slip and wheelspin you have. Gears snap off when people give them a real hard initial shock loading over and over. You just want it sitting right on the edge of that bite point and then when your ready to go you just let the clutch out smoothly that little bit and it will take up and then your off.
Construct Sep 13, 2023 11:24 AM
R.I.P.
Making Aaron's instagram page is an accomplishment, but an accomplishment I would prefer to avoid.
Which twin plate do you use?
Also, where are you launching? I wouldn't have thought you'd be launching with the type of racing you do, but apparently I don't entirely know what you're doing
Dallas J Sep 13, 2023 11:29 AM
Theres also a difference between launching at a track and launching drag style. Its only a few tenths worth of time, but a 1.5-1.6 60ft is an order of magnitude more harsh than a 1.8-1.9 60ft. I can launch 1.7s all day long. When I push that down to the 1.6s its way more aggressive.
Bee-Raddd Sep 13, 2023 01:45 PM
Originally Posted by Construct (Post 11972449)
R.I.P.
Circuit racing with standing starts. Tilton twin plate.
Bee-Raddd Sep 13, 2023 01:46 PM
Yep thats fair. Definitely could launch harder. I also have quite tall gears with a short final drive which helps also
ViciousLSD Sep 13, 2023 04:47 PM
Do you guys even race? asphalt? lolz
j/k
MrAWD Sep 13, 2023 06:13 PM
It looks like I have a new project to deal with! Today, my exhaust just dropped all of the sudden and I had to drag it back home like that. Luckily it wasn't a long trip. It looks like all the hangers that I have on that part of the exhaust were fully corroded and detached from it. I will try to go to the great local exhaust guys (Lue's Custom) with hopes they could put it back to working condition.
https://cimg9.ibsrv.net/gimg/www.evo...63d0b6d247.jpg
https://cimg0.ibsrv.net/gimg/www.evo...7b4435e5b3.jpg
If not, what are my options for a not too expensive cat-back - any recommendations?
Fedja
kikiturbo Sep 14, 2023 03:07 AM
I think you need to sort that underbody rust first.. .I just restored a X for a friend and it gets ugly quickly..
Dallas J Sep 14, 2023 07:48 AM
That amount of rust is scary. Very happy to not have a car from the rust belt.
Ayoustin Sep 14, 2023 09:43 AM
https://cimg7.ibsrv.net/gimg/www.evo...17b691e7ed.jpg
