The evolution of my Evo IX RS Wicked White
Old Mar 4, 2015 | 04:57 PM
  #286
High_PSI's Avatar
Amazing thread, amazing skills.
Old Mar 8, 2015 | 03:31 PM
  #287
michaelrc51's Avatar
Any pics of that diffuser finished up?
Old Mar 8, 2015 | 05:30 PM
  #288
AreSTG's Avatar
i need to get my hands on some alumalite to feel it. I bought ABS, because the description of alumalite sounded... confusing. But thick ABS is surprisingly heavy, and also ABS is easy to melt.
Old Mar 8, 2015 | 06:00 PM
  #289
You in Pa?
Alumalite is basically like cardboard but the outside pieces are thin aluminum and the inside is corrugated polymer.
http://www.harborsales.net/Home/Prod...arch=alumalite
Old Mar 10, 2015 | 08:17 AM
  #290
honda-guy's Avatar
here's some pics of my rear diffuser. got some recommendations from chad at cbrd and this is what i end up with. i wanted quick release at first but the mounting design was too complicated. i wanted to get it done quick. maybe i'll redesign and make another one that's quick release later. this one removes pretty quick, just 5 bolts in about 2 minutes. putting it back on takes about 5 minutes. this is just in case i need to remove it to get the car on and off the trailer, or use the rear tow hook to strap down for dyno. i can probably also use the rear T-hooks to strap the car down for dyno but haven't tried that yet. my first track event will be next weekend at VIR. i'll try testing with lowest wing settings. maybe even take the wing off the see how the car does without the rear wing. i still have my old front splitter, but i'm planning on making a larger one, so i'm sure ill need the rear wing back on for that.
used foam board to get some proximate dimensions and clearance.
originally was going to have the diffuser hang under the exhaust which means it will be lower than the control arms. but then i moved it up, about level with the fuel tank, because i didn't want it to catch too much air.
i was able to use an tank roller at my friends shop. took us several tires. but we were able to get a nice bend on it afterward.
front mounting bracket that just slides in
driver side bracket
passenger side bracket
one rear bracket
got one nice weather day couple weeks ago. perfect timing to paint the brackets.
Old Mar 10, 2015 | 06:16 PM
  #291
AreSTG's Avatar
Originally Posted by michaelrc51
You in Pa?
I'm a PA resident (southeast PA), but stationed in NC
Old Mar 10, 2015 | 06:17 PM
  #292
AreSTG's Avatar
Thanks for taking such detailed pictures on the diffuser
Old Mar 10, 2015 | 07:32 PM
  #293
I am not far away from SE Pa if you come home and want a sheet. I am just across the river from New Hope.
Old Mar 10, 2015 | 07:35 PM
  #294
Nice work Thai!
I think it is about as close to QR as possible. I guess you could use some Dzus fasteners instead of bolts to make it really QR.I would think 5 mins is quick enough.
Old Mar 10, 2015 | 08:38 PM
  #295
honda-guy's Avatar
Dzus are old school. I'm going with these new quik latch for my front splitter
Old Mar 11, 2015 | 04:42 AM
  #296
There you go. Definitely much stronger.
I have that for my front bumper quick release.
Old Mar 11, 2015 | 05:16 AM
  #297
High_PSI's Avatar
How big of a difference does that diffuser make? What are the main benefits?
Old Mar 11, 2015 | 10:46 AM
  #298
honda-guy's Avatar
haven't test on track yet. only drove on highway a couple times to make sure it doensn't fall off at 80 mph. lol
a functional diffuser will generate downforce more efficient than a wing, less drag. don't know if mine is functional or not yet.
Old Mar 12, 2015 | 06:34 AM
  #299
AreSTG's Avatar
I'm interested in lowering drag. Let us know if you can notice you're approaching turns at a higher speed than before
Old Mar 12, 2015 | 08:38 AM
  #300
honda-guy's Avatar
I have AIM data from a few track event last year. Will be able to compare data. Also, I can take the diffuser off at track and do comparison on the same day.
