The evolution of my Evo IX RS Wicked White
I suppose if staying in TT4, you wouldn't need to remove all that interior except maybe for the purpose of offsetting the added weight of a cage?
Are you running ballasts to get the weight up in TT4 trim (about 3,380lbs)? Down the road, I might want to try TT4, so want to see what sort of adjustments I need to make.
I’m surprised you can’t lower your power with just a simple restriction in the intake or exhaust?
restricting exhaust will effect turbo spool and increase exhaust temp. adding restrictor to the turbo inlet is possible but i didnt want to mess with that. i had and evo 8.5 turbo that i was going to put on, that would reduce top end flow, but still have the larger turbine housing.
Heliart
15
Oct 2, 2023 02:33 AM
Green_Bandit
21
Sep 9, 2019 02:14 PM
EvoDan2004
72
Sep 10, 2017 07:29 AM
chetrickerman
Aug 23, 2017 07:22 PM
