Live4Redline's DE-Evolution G4JS Budget Build
Old Jan 4, 2012 | 01:49 PM
jzt's Avatar
jzt
Does that valve cover bolt onto the evo head without mods? I like the Kia/Hyundai oil caps better; they thread in, like on Hondas.
Old Jan 9, 2012 | 09:15 AM
Live4Redline's Avatar
^ No, the valve cover will not swap over. Would need to swap the whole head.
Old Jan 9, 2012 | 11:07 AM
Quick Update: I tryed to use the factory Kia knock sensor mostly becouse I forget to swap them out before I got the motor in the car. I re-pined it and gave it a whirl. As I suspected i ran into a lot of false knock (upwards of 32 counts) that I tryed to tune out by adjusting the knock sensitivity map but it wasnt working out so with the help of two additional people, a 6ft extention, a ground down snap-on socket with a swivel attached we threw in a Evo knock sensor and full throttle got two counts of knock before we ran out of road.
Havnt had the chance to get a full tune on the car yet but pending some warmer weather and a thing or two to get it legally back on the road so I dont get a ticket on the way to the dyno, we should have somr results. (Need a windshield, Passenger Side Fender, exhaust and an inspection sticker.
Old Jan 10, 2012 | 05:33 AM
mysticj's Avatar
Is it possible to use the 4G61/G4CR stubby oil shaft, commonly uses for the B/S kit?
Old Jan 19, 2012 | 04:59 AM
Yes, the Evo balance shaft delete kits will work on the G4JS block, both seals and stub shaft.
Old Jan 21, 2012 | 08:37 AM
mysticj's Avatar
You know the G4JS timing belt layout reminds me of the 4G92/3 DOHC layout.
Old Jan 21, 2012 | 09:46 AM
STWHY?'s Avatar
Man...thats pretty cool and very original..Keep up the good work...Justin
Old Feb 5, 2012 | 01:00 AM
Ill agree, its closer to the 4G92/3 DOHC layout then it is too the Evo Layout.
Old Feb 6, 2012 | 07:11 AM
mysticj's Avatar
Well the timing belt tooth pitch or gap for the 4g15 sohc is the same for the G4JS just narrower. If only I can get the diameter of the 4G9x cam gears, if its the same as G4JS then their will be a way to adjust cam timing.
Old Feb 7, 2012 | 10:54 PM
Can you post a picture of the cam gear? The G4Js pattern is a lot diffrent then what I've normaly seen on Mitsubishi's.
Old Feb 9, 2012 | 12:43 PM
mysticj's Avatar
I couldn't find a 4G15 or 4G93 cam gear in the yard for nothing, but I do have the 4G15 timing belt[piece of it]. The belt fits but its narrower than the G4JS belt.
Planning on swapping the G4JS shortblock into a 7G Galant soon.
Old Feb 18, 2012 | 04:58 PM
mysticj's Avatar
L4R, do you know the diameters for the 4g9x cam gear?
Old Feb 22, 2012 | 02:02 PM
DavidCLy's Avatar
nice build
Old Mar 7, 2012 | 07:34 AM
pupo's Avatar
Very nice!!!
Old Mar 20, 2012 | 11:08 PM
David Seaborne's Avatar
need help on my 4gjs...
I own a 2004-2005 KIA optima and I'm desperate for power... I want to make a fun car out of my budjet car buy. It's got an excelent condition motor replacement but I want to get some real power out of my 2.4l I have many questions but I'd like to hear your personal view .
