Kracka's GheyrodX - bigger, fatter, gheyer!
Old Feb 24, 2012, 06:27 AM
  #46
MJ23FE's Avatar
Krack, nice update.
Is that a MAP fabricated manifold, or a rebadged TiTek?
-Jalal
Old Feb 24, 2012, 06:33 AM
  #47
Kracka's Avatar
MAP does not fabricate the short-runner in-house. There are multiple companies rebadging it, but MAP backs it up with a lifetime warranty against cracking, offers coating, makes an array of heatshields, plus prices it very competitively.
Old Feb 24, 2012, 06:45 AM
  #48
MJ23FE's Avatar
Which are all the things that I love that they do with this product! However, I also think very highly of their porting services as well!
-Jalal
Old Feb 24, 2012, 06:50 AM
  #49
Kracka's Avatar
As do I, and I currently have a ported/coated ex mani on the car, but you can't argue with their dyno testing results thread
https://www.evolutionm.net/forums/ev...o-results.html
Old Feb 27, 2012, 05:38 PM
  #50
Kracka's Avatar
Full professional detail yesterday!
Not bad at all for 33k miles I'll try and get better pictures eventually, I just snapped these with my phone tonight in my garage.
Old Feb 27, 2012, 05:59 PM
  #51
HAHAV8's Avatar
Cool journal Kracka, it is very well documented!
I just have a random question. Why do you say that X's don't do well with certain intakes with the A/C on? What exactly do you mean by this?
Old Feb 28, 2012, 06:23 AM
  #52
Kracka's Avatar
An intake that isn't properly designed will see turbulence at the MAF from the A/C fan. Turbulence at the MAF will lead to an unstable idle/stalling condition. The AFE intake that I run is still far and away my favorite intake design for the X, followed probably by the K&N. The filters are in the correct spot, the stock MAF housing is retained, along with nice large heatshields that utilize the factory air scoop.
Unfortunately, I may be needing to upgrade to a larger (3") intake fairly soon since I'm currently hitting the max 5v in the stock MAF housing on really long high-gear high-RPM pulls. I'm thinking I may actually custom fabricate a 3" elbow to replace the 2.75" AFE tube and stock MAF housing rather than buying something from off the shelf.
Old Feb 28, 2012, 09:56 AM
  #53
jyamona's Avatar
that heat shield for the short runner is nice! did MAP make it? and how will it work w/ gaskets then?
Old Feb 28, 2012, 10:24 AM
  #54
airgazem's Avatar
Nicely put together I enjoy seeing progress! Also the detail work and parts +1!
Old Feb 28, 2012, 11:51 AM
  #55
Kracka's Avatar
MAP did make it, and I plan to run a gasket on either side of it. Or maybe it will act like a gasket itself? I'm not sure yet to be honest.
Old Feb 28, 2012, 01:02 PM
  #56
jyamona's Avatar
those were my two thoughts haha
Old Feb 28, 2012, 05:38 PM
  #57
Playap07's Avatar
Your build is pretty sick! You got yourself a sexy *** X! That detail job is legit! You make me want to get a detail done on mine.
Old Feb 29, 2012, 10:26 AM
  #58
Kracka's Avatar
Thanks...and do it!
Old Mar 1, 2012, 04:08 AM
  #59
anasmak11's Avatar
Any results with the MAP mani yet?
Also, I want to buy ur stock ported exhaust mani now. How much?
Old Mar 1, 2012, 05:32 AM
  #60
SavageGSR's Avatar
had to ask did you go with the AFE dry or Oiled filter, i understand the pro's and cons and was interested in your thoughts.
Quick Reply: Kracka's GheyrodX - bigger, fatter, gheyer!
