MAP Stage 2 LR 2.4L Build
Old Dec 29, 2013 | 08:47 AM
  #766
Blue91lx's Avatar
Originally Posted by batty200
Well now we will have a definite comparison between the red and a 6262. If the red is spooling awesome and making great power then we know. I am so undecided. I love the power I have but also loved my spool on 20G. I do like that I can crank the boost and make an additional 200whp. At 17psi I made 400whp. At just under 23 it made 515whp. At 27ish 565 but I think that will be surpassed since I upgraded to a CEA turbine wheel and to a ceramic DBB from a Garrett chra.
Indeed we will! Should be a super sweet comparison to overlay. I think I'm definitely too much of a response junky to jump to a T3 setup. Maybe someday a TS T4 and an EFR or something. I would really like to ride in your car and get a feel for the response.
Those are killer numbers, especially on such low boost.
Originally Posted by 4g63evoeight
for the short time i had the black on the car it made 630whp/570tq VD... didnt get a chance to run it at the track but with 450vd it went 125mph for reference.. this was on a 2L, stock TB and intake manifold. rolling into the throttle from a 40roll on drag radials it would just melt the tires on 70* nights. it was very torquey. didnt feel it was lazy at all.
That's a good reference to have. Even compared to your stock turbo it didn't feel lazy?
Originally Posted by tscompusa
Don't get me wrong if you went from an FP red to an FP Black you would definitely feel the difference in lag. I dont know how you are with cars, but if you are someone who wants no lag at all then it could very well be possible you wont like the black over the red.
On paper they are very similar, but driving the fp red is going to be a lot more responsive in everything you do.
Your mods and displacement + the red is going to be extremely fun and i think it will keep you more then content. it will be a handful for auto X for sure.
I see you hitting full boost around 3600RPM in 3rd easily. and its going to make a lot of power per boost because you have the right bolt ons.
You are correct. the fp black is more like a 3582R
You are also correct the red is the middle man of the green and black, which technically it is the best of both worlds. its a mix between a larger turbo and a smaller turbo. so you are going to have some of the snappy response like a smaller turbo, and the top end like a large turbo.
It does seem like they are more prone to failure though then the other fp turbos. i dont know if its because its just big enough to easily overspin itself or what, but when you tune it dont push it to hard. i think you can reach your goal at about 30psi.
I used to have a fp red on a stock block and it was a very fun setup. Its a lot more responsive then a black is on a 2.0L. 250RPM may not seem like a lot, but it really is when you're in the car and feel it.
That's good to know. I probably won't push it too hard for more than a pull or so.
I can't seem to get my front 02 sensor to read after I switched back to a Stock ECU so I may have to grab another series 1 box to throw in there to get the tune 100%. Or just do open loop, we'll see.
Old Dec 30, 2013 | 09:23 AM
  #767
4g63evoeight's Avatar
not really, it was deff a noticeable change.. however the car was more enjoyable to drive around the city and highway since you weren't always in boost having to feather the throttle. stock turbo was almost too responsive
Old Jan 1, 2014 | 12:21 PM
  #768
Blue91lx's Avatar
I know how that is, and I'm definitely going to miss it.
I'm worried about my fuel system for the Red setup. 1250s and a 400 isn't going to be near enough for FP Red on E85. May be pump gas and race gas until I can afford a DP and 2150s (which will be never).
Old Jan 1, 2014 | 08:03 PM
  #769
Blue91lx's Avatar
Quick question. I need to pick up a slim fan, as my stocker with the fat Koyo isn't working out too well clearance-wise.
Does anyone have experience with the 12" FAL? I'm planning on picking this guy up and wanted a second opinion:
http://www.streettunedmotorsports.com/parts/fal_fan.htm
Old Jan 1, 2014 | 09:23 PM
  #770
EvilTechnology's Avatar
Been following your thread forever man. Have a BB Red sitting here, and a 2.2L in the garage with all the fixin's waiting to be installed.
Looking forward to seeing how you like the Red
Old Jan 3, 2014 | 01:50 PM
  #771
Blue91lx's Avatar
Man, that's gonna be a nasty setup! What variation of a 2.2L is it?! I would've loved to build a destroked 4g64.
Lend your ears to some beautiful straight 6!
Old Jan 3, 2014 | 02:22 PM
  #772
4G63, 94mm Eagle crank, stock length Oliver rods, CP pistons 9.3:1, English Racing(Jeff Bush) ported head 1mm over, S2's etc.
Old Jan 4, 2014 | 09:09 PM
  #773
Blue91lx's Avatar
That's going to be a killer setup! I'm rethinking my S3 decision.
Old Jan 19, 2014 | 05:46 PM
  #774
Blue91lx's Avatar
All back together! Now I just need a slim fan, some Brad Penn, and a tune!
Old Jan 19, 2014 | 05:58 PM
  #775
MaLo EvoVIII's Avatar
Looking pretty nice under the hood.
Old Jan 20, 2014 | 01:09 AM
  #776
Evo_AK's Avatar
Veteran: Air Force
Looking beautiful! What are your whp goals on this setup?
Old Jan 20, 2014 | 01:57 AM
  #777
batty200's Avatar
Is this stock turbo? Looks great!
Old Jan 20, 2014 | 12:47 PM
  #778
Blue91lx's Avatar
Thanks, man! I'm hoping to make close to 600/600 on high boost/Ethanol, and hopefully hit around 450+ on 93 octane.
Nope, this is the Red setup! Thanks, man.
Old Jan 20, 2014 | 12:49 PM
  #779
aggieEVO's Avatar
Sweet! So close!
Old Jan 27, 2014 | 08:44 PM
  #780
Blue91lx's Avatar
Originally Posted by aggieEVO
Sweet! So close!
Yes!! Still awaiting oil and a fan. I should've listened to you about not falling too deep in the E30. I'm afraid it's even taken priority over the Evo
