BlueByYou Build-up - By:si937
Thanks man. Yeah i was just about to have someone else do it. i guess this way i can take my time and make sure its done right. ha but it sure is a pain.
Thanks man!
- Well things have been at a stand still some what. My dad has been talking about wanting to get a ETS small battery kit & short route Up-pipe kit for his evo for quite some time. Since my car is gonna be down for a while we had worked out a little deal so for the weekend i worked on his car
- 3in Wiggins clamp
- Banjo to 4AN fittings
- Got a new starter and all the outter seals for the transmission. Just waiting on the felt bushing for clutch release fork shaft. Hopefully will be here tomorrow
- Also got my STM Clutchline, Fork stop, IM Gasket, EGR delete and PTE seal kit
- Installed the new caps and seals for the Injectors
- Pulled of the manifold to port-match, bore TB and EGR delete
- Im going to try and clean up the casting imperfections
- Surpised how off it was from the gasket. Laid the gasket over the top so you can see the difference
- Ill probably start porting on Wednesday so ill let you know how it goes. Hopefully by the weekend i can have the part to finish installing my clutch and transmission.
Thanks man!
- 3in Wiggins clamp
- Got all my seals installed in my trans and reinstalled it back in my car. I again started to go through some of the stuff and one thing i was messing with was my vacuum lines off my boost controller. Ran into this problem.
- I notched out the corner so it would clear and had a piece welded back in and then i sanded it smooth.
- I got my Full Blown Throttle body in and had my Wiggins clamp welded on. Also had the adapter plated welded on the manifold and bored out.
- On my spare time i decided to clean and paint my starter plate and shifter bracket with wrinkle black paint. Pretty stoked how it came out.
- Assembled all the important stuff so we can finish the fab work.
- I got my 2.5 intercooler piping, Speed density kit, 3in vband, and Tial BOV on friday. Dropped my car off at my friends shop today and we are going to start working on it tomorrow so we will see how it goes. The down pipe is going to be a pain!
Well after a week of waiting, we got all the fabrication finished. Excited how well it came out. My buddy Josh at TrueMetalShaping did a amazing job. This is different from what he normally does so it did take him some time but his precision and craftsmanship is top notch.
https://www.facebook.com/TrueMetalshaping
We first tackled the Exhaust down pipe. Tight but got it to fit with enough clearance.
3in O2 housing with Vband
Intercooler piping was held up mostly because of me. I wanted a design that went from 3in off the throttle body, then tapered down to a 2.5in for a cleaner look. One of the companies that would of built me a cone to my dimension wanted a lot of money. With Josh's profession, he was able to build what i needed with no problem. The Pegasus clamps i had bought needed to be machined a little bit larger to go over the top of the piping and then was welded on the inside for a cleaner look.
Changing my mind again i had ordered clamps to put on my compressor housing. Had the compressor inlet machined to fit the 3in ferrule. Had to use a adaptor from 2 to 2.5in for the compressor outlet. Totally forgot to machine the outer edge so it wouldnt have the step down look.
Tomorrow we are going to finish the intake piping and weld in the bung for speed density.
Not much has been going on with the evo. Still waiting to get it dyno tuned but not long ago i was invited to get some moto footage with my buddy Logan Binggeli who kills in on a mountain bike. Told him we should get some clips rallying my evo in there.
Check it out!!
http://www.pinkbike.com/news/logan-b...ideo-2013.html
