Badev0's Build Thread *Part 2*
Old Feb 9, 2013 | 09:46 AM
  #256
badev0's Avatar
Tires arrived today. I'll get them mounted and some pictures of them on the car soon.
Old Feb 15, 2013 | 06:44 PM
  #257
mitsubeastlee's Avatar
1 word = RAW
Old Feb 21, 2013 | 06:46 PM
  #258
badev0's Avatar
Here are the lug nuts I am going to use for my stock wheels on the street They are OEM toyota/lexus lug nuts. 10 for the front. Do not need arp extended studs for the rear.
Currently the injectors are with FIC getting cleaned for 2013.
Old Feb 21, 2013 | 07:59 PM
  #259
Wheatley's Avatar
Thanks for sharing those! I wondered if there was an oem open with a shank
Old Feb 21, 2013 | 08:00 PM
  #260
Wheatley's Avatar
After I switched to the rotas I actually don't need extended studs on front or rear.
Old Feb 21, 2013 | 08:33 PM
  #261
badev0's Avatar
I will post up the link to where I bought them tomorrow.
Yeah I need the extended studs for my spacers I have to use for the 15x7 Slipstreams I'm using to clear the brakes up front.
Old Feb 22, 2013 | 06:21 AM
  #262
antilag_200's Avatar
You can shave the stock lugnuts if you are in a pinch next time .
Old Feb 22, 2013 | 06:23 AM
  #263
badev0's Avatar
I was thinking about it, but it sounds like a bad time with my angle grinder in the garage lol.
Old Feb 23, 2013 | 04:17 PM
  #264
badev0's Avatar
Finally had my friend mount up the tires today. They fit and look pretty good.
Rear:
Front: Not bolted on because I need to throw on my ARP extended studs still. There will be a 10mm spacer behind the wheel.
Going to be putting these EVO 9 MR tail lights on the car, except i'm adding special vinyl to them so they appear as EVO 9 JDM tails
Old Feb 23, 2013 | 04:36 PM
  #265
LGshow19's Avatar
Rear:
Those Hoosiers are looking good
Old Feb 23, 2013 | 07:26 PM
  #266
badev0's Avatar
Thanks man!
Old Feb 23, 2013 | 07:30 PM
  #267
badev0's Avatar
I added the amber/orange vinyl to the 9 MR tails.
Before
Orange/amber transparent found on ebay for under $10. It's pretty thick.
Create template
Cut vinyl then apply water/soap solution to the headlight surface and on top of the vinyl
Get all air bubbles out with a squeegee/vinyl applicator/or credit card. Use a heatgun while doing this if there are any imperfections.
Done
Now to enjoy some JDM IX tails
Old Feb 23, 2013 | 07:58 PM
  #268
LGshow19's Avatar
Im doing the same thing to my evo9 tails I picked up awhile again, vinyl/tint same thing... looks nice man!
Old Feb 23, 2013 | 10:31 PM
  #269
MRfabolous's Avatar
looks nice what kind of tires did you get. i just picked up a set of MnH g60 235/60/15 i have them on rota slip streams also will post pics up soon.
Old Feb 24, 2013 | 07:55 AM
  #270
badev0's Avatar
Thanks man! Yeah, can't go wrong doing it! Save some good dollars too instead of buying the real thing.
Thanks sir. They are 26x9.5-15" Hoosier quick time pro.. dot approved "cheater slicks". Wheels are 15x7.
Nice man sounds good.
