Badev0's Build Thread *Part 2*
Old Mar 25, 2013 | 10:00 AM
  #331
Wheatley's Avatar
Cage!
Old Mar 25, 2013 | 12:07 PM
  #332
06MREvo's Avatar
Originally Posted by badev0
To add to this build, the car is getting caged this weekend. It should be finished by next weekend.
It will be a 10pt choromoly with window net, certified for 8.50's. Safety first right? lol.
Cage, oh sh*t! Plan on still keeping interior with the cage?
Old Mar 25, 2013 | 12:52 PM
  #333
5LEEPERISAH23I's Avatar
Dont do it! it wreacks the car! IMO
Old Mar 25, 2013 | 01:02 PM
  #334
badev0's Avatar
Originally Posted by Wheatley
Cage!
Yes! As you already knew
Yep, 100% full interior. You shouldn't even be able to tell it has a cage unless you look in the car. It'll be a very clean/tight fit
I'm sick of not being able to participate in many of the events locally from not having one, and they do stiffen the chassis and safety is #1. Only thing I have to modify on the car is notch the dash a bit, but it doesn't ruin the car at all
Old Mar 25, 2013 | 01:42 PM
  #335
way2qik's Avatar
I'll be putting the new plug in probably tomorrow and also checking the head stud TQ again, I don't think I have done so after the car seeing boost on this new motor.
Scott, I ended up having my machinist machine the block for screw-in freeze plugs for exactly this reason. BTW, I'm willing to bet that once you check the torque on those head-studs you'll find the reason it pressurized the cooling system. The same thing happened to me when I forgot to check the studs after a few initial heat cycles of a new build.
I'm really interested in seeing the results of the intake change, too. Best of luck.
Old Mar 25, 2013 | 01:47 PM
  #336
badev0's Avatar
Screw-in freeze plugs, that is pretty bad-*** and not very surprising since you came from the V8 world. Yes, I am almost positive that is the issue.
I should have the new results up this weekend with freeze plugs intact The results I post this weekend may not be the same boost if I don't figure out the misfire issue, could be a failing coil from the spoolin-up set, not sure. But you will see the curve and could tell what power could be made.
Old Mar 25, 2013 | 02:07 PM
  #337
Wheatley's Avatar
Hondas use screw in freeze plugs as well. Just hard block it and the freeze plug goes away lol.
Old Apr 1, 2013 | 06:07 AM
  #338
badev0's Avatar
Car is up and running good. Freeze plug probably wasn't sealed very good plus the bad misfire caused it to pop out. Compression and leak down was perfect.
Here's a comparison between the f1i and curt brown 70mm extreme at 34psi. Only changes in the before/after pull was the f1i was in 15* weather, no tuning here.. Not sure if this is accurate or not, I can tell the car is a lot faster though, possibly the tq speaking. Curt brown says the results are spot on and the only intake manifold in his testing to see similar results was a ported skunk 2.
Accurate or not, it spools faster, makes more boost, and doesn't fall off up top. This power level in my car will trap between 144-146.
got around to installing the ARP extended studs:
Two random pics my friend took at a car meet I was at over the weekend
Old Apr 1, 2013 | 06:17 AM
  #339
LGshow19's Avatar
Looks badass.
Car is going to make nice power on kill!
Old Apr 1, 2013 | 06:25 AM
  #340
badev0's Avatar
Originally Posted by LGshow19
Looks badass.
Thanks man. It should make pretty good power. I'm honestly really happy with the power level it is at right now so we won't be pushing it TOO much harder.. for now.. lol. I never got a clean pass at the drag strip with this power level last year so i'd like to see how quick I can drive it down the 1320
Old Apr 1, 2013 | 06:33 AM
  #341
way2qik's Avatar
That's a great result Scott. Car looks great. Love the wheel studs, too. Where did you get those?
Old Apr 1, 2013 | 06:37 AM
  #342
badev0's Avatar
Thanks Dan! I got them through STM:
http://www.streettunedmotorsports.co...heel_studs.htm
Old Apr 1, 2013 | 06:59 AM
  #343
Evosick2332's Avatar
Great results Scott! Car is going to run like an animal!
Old Apr 1, 2013 | 07:12 AM
  #344
antilag_200's Avatar
SICK 3 weeks and counting to 9s
Old Apr 1, 2013 | 07:14 AM
  #345
badev0's Avatar
Hopefully man!!!! I think I will be attending the Lansing show as well the day after our meet at the strip
