Badev0's Build Thread *Part 2*
Old Oct 18, 2014 | 03:06 PM
  #676
badev0's Avatar
Originally Posted by IzzyRS
The build thread section just isn't the same without your thread being updated regularly!
Well thank you! I'm back to updating regularly
Originally Posted by mitsubeastlee
thanks for the reply badevo!
did you convert ALL vacuumlines to push lock or jut the turbo, wg and bov?
for the intake mani you would have to drill and tap and weld im sure?
Yes, we converted every vacuum line on the car. A few had to be drilled/tapped.
Old Oct 18, 2014 | 04:08 PM
  #677
mitsubeastlee's Avatar
ahh gotcha! thanks
Old Oct 18, 2014 | 07:07 PM
  #678
MICHAEL1's Avatar
epic, simply epic!
Old Oct 19, 2014 | 06:18 AM
  #679
michaelrc51's Avatar
Nice build.
I think I am going to convert all mine as well.....maybe on next year's list....
Originally Posted by badev0
Oh and these push lock fittings are amazing!!! Rated to 250psi. Never again am I touching vacuum line...
Old Oct 19, 2014 | 07:16 AM
  #680
badev0's Avatar
Thanks guys!
AEM coils getting wired up:
Here's how the lower IC pipe came out. Much shorter than your average FF LICP. It's also no longer crammed near downpipe, radiator, etc. This was fabbed by Cory @ Deadhooktuning. I'll post a picture of the upper tonight!
Attached Thumbnails Badev0's Build Thread *Part 2*-15387618500_e04f201ac0_c.jpg
Old Oct 19, 2014 | 07:50 AM
  #681
jeffbeagley's Avatar
Car's coming together bro, looks great! Push locks ftw. I had every intention of replacing the rest of mine ( intake manifold ) when I had it off next. Completely changed my headgasket and forgot all about ordering the fittings
Old Oct 19, 2014 | 10:26 PM
  #682
evo7_8u's Avatar
looking good man , lower ic pipe looks awesome .
Old Oct 20, 2014 | 06:04 AM
  #683
badev0's Avatar
Thanks sir! And damn... next time right?
Thank you sir, I agree!
Old Oct 20, 2014 | 06:08 AM
  #684
badev0's Avatar
Upper pipe was finished last night. Only thing left to do is re-do the WG dump. I think we're going to do a tear drop. We are also going to make a dump that goes under the car to comply with the street eliminator rules at next years shootout.
The radiator isn't perfectly spaced from the radiator support but I am going to fix that with an adjustable black spacer.
One last thing, the turbo that is on the car was suppose to be a 6266. I bought it 2 years ago from MAP. This weekend I realized the sticker on the compressor cover inlet said 6262... Need to measure turbine wheel... I would find it funny if it was really a 6262 the whole time.
Old Oct 20, 2014 | 09:42 AM
  #685
06MREvo's Avatar
9 lbs of wiring, nice! $300 for 4 coils, pretty silly price! You don't see many people run that setup at all, so I am very interested in seeing your results! Nice updates sir!
Old Oct 20, 2014 | 09:46 AM
  #686
badev0's Avatar
Thanks sir! I'll be sure to post results
Old Oct 24, 2014 | 08:33 AM
  #687
420a-t's Avatar
Originally Posted by michaelrc51
Nice build.
I used that line a few years back, be careful when using close to something hot aka your wastegate by the mani. I had a few lines melt on me, as they hold air really well, but they're super thin and plastic so they tend to melt easily.
Car looks awesome man! Keep up the good work and not hitting any walls at the track!!! (saw that vid, crazy)
Old Oct 27, 2014 | 02:10 PM
  #688
Benja's Avatar
Yep as above.
I wouldn't use them on the wastegate side with possible heat sources close by.
Client had them on his car off the gate, they melted and he was boosting to the moon.
Old Oct 27, 2014 | 02:21 PM
  #689
badev0's Avatar
Originally Posted by Benja
Yep as above.
The line that I have does pretty well with heat, it takes some time under a direct flame to get it to shape. I will use a small DEI sleeve to protect it to be safe
Old Oct 27, 2014 | 02:22 PM
  #690
badev0's Avatar
Also, I will be hitting the track this weekend! (Nov. 1st)
