Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old May 16, 2013 | 06:57 PM
  #616
mullen's Avatar
Weight reduction first, then comes the bling
Old May 17, 2013 | 10:05 AM
  #617
06MREvo's Avatar
So T-stat housing & nipple on the water pipe are both welded closed now? Looks good Dan! Also, why the hell is there so much oily dirt on/near your T-stat housing? Was your cam angle sensor housing or something in that area seeping?
Old May 17, 2013 | 04:51 PM
  #618
EvoDan2004's Avatar
yes all welded closed. i had a new T-Stat cap made too. ill get pics of that up in a min. i left it out of the other pics on accident trying to show the water line delete stuff.
Old May 17, 2013 | 05:18 PM
  #619
EvoDan2004's Avatar
here are better pics of the cap. the reason for this is my radiator sits lower then the T-Stat housing. so filling the system and getting all the air out is a royal PITA. so i had this made. my last one was basically the same but had a fitting on it for a water temp gauge and i no longer have the gauge so i wanted a cleaner look. i know i have issues.
today i got the 2 rear brake lines in, and fuel feed line back in. i am on hold because i am waiting for some parts to show up. until then it is basically doing the small boring things.
Old May 17, 2013 | 05:41 PM
  #620
EvoDan2004's Avatar
Originally Posted by Anna4ba6xter
So i would like to get them in along with buying a few other bushings from STM to complete the setup. I am hoping this will help get the car off the line better.
? what?
Old May 18, 2013 | 04:02 PM
  #621
EvoDan2004's Avatar
does anyone have a TS or Avid rear trans mount they can weigh for me. i believe there heavier then stock but i want to make sure. i was gonna put the rear trans mount assembly on and the mount looks like crap and i do not want to use it. HA.
also my ceramic wheel bearings are back off the car and going to Curt for a little ''update'' on them. cant wait.
front rotor hats are off the disc and ready to be shipped out monday.
Old May 18, 2013 | 04:31 PM
  #622
joseph143's Avatar
Any noticable benefit from the bearings? Also i have both but no scale to compare the weights... I'm sorry...
Old May 18, 2013 | 04:38 PM
  #623
EvoDan2004's Avatar
Damn you. Throw them in the air and the heavier one should hit the ground first haha.
Yes. And the update I am getting is supposed to be a huge difference. I'll have all the details once I get them back
Old May 18, 2013 | 07:41 PM
  #624
tsidrift1's Avatar
how much of a pita is it to remove the wiring harness from the bay?
Old May 18, 2013 | 08:34 PM
  #625
EvoDan2004's Avatar
mine or a stock one?
mine pretty simple. a stock one is a PITA. you have to pull the center console off and deal with all that crap.
Old May 18, 2013 | 08:43 PM
  #626
tscompusa's Avatar
Dan is your block half filled at all or none of that? I was contemplating on doing that with my 4g63, but the more i think about it, its prob not necessary on the 4g63 block.
Old May 18, 2013 | 09:24 PM
  #627
EvoDan2004's Avatar
currently no it is not at all. 100% wet. i do plan to go with a high rev 2.3L next year and will probably semi fill it. but i do not think it is needed. also IMO bore size plays a big part in that.
Old May 18, 2013 | 10:24 PM
  #628
tscompusa's Avatar
yes absolutely. the more you bore it out the thinner the walls. .20 over on a 4g63 would be the maximum i'd say for safety.
i am not going to worry about filling a 4g63, the 4g64 on the other hand will be half filled without compromising the cooling passages so it is still street friendly.
Old May 19, 2013 | 09:07 AM
  #629
joseph143's Avatar
.020 over on a 63? Why so low when its been done so many times over to .040? Or are you only speaking of a hi reving motor?
Old May 19, 2013 | 09:29 AM
  #630
tsidrift1's Avatar
Ye, I was asking for stock. I have looked a little into it, seems like a huge pita. Looks like there is a lot of harness that goes under the dash and all.
I miss my 1g dsm, harness went through the firewall and to the ecu haha.
