Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
well i am going to start on the wiring. i am in the mood to work on it some right now. i could use your guys help greatly here. i almost do not want to bother but i am going to remove what i do not need and then just leave it alone. ill get some pics up on what i plan to remove. some of the stuff i forget what it is for so i hope you guys remembered HA.
lets hope not. once this is done and the car is together i will install the harness. if it works then great. if not i am ripping it out and buying another new one and never doing this again. i wont even waste my time trying to figure it out
thanks for telling me this now. some friend you are turning out to be.
i removed 5 other connectors this morning. in the event this does not work then i will either buy a new one and never do this again or ill give you a shout and buy what you have. Jason i am not sure i told you the horror story about the ChaseBay harness i bought which never worked. holy crap man.
This went a lot faster then i expected. granted i did not do much LOL. now lets just hope it works. i removed all the sensors and connecters i do not need. i believe it was about 6 or 7. i also re routed some sensors to be inside the car instead of in the engine bay. i am now done with wiring.
here is a few pics. i re routed the wiper motor wires to be inside the car and i will make a new hole for it to feed into the wiper compartment. i also re located the 3 sensors for the fuel injectors or whatever there called.
i just have to pick up some wire loom to wrap up the wires. otherwise it is done
