Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old Apr 7, 2013 | 10:18 AM
  #481
EvoDan2004's Avatar
It should clean it up some for sure. I also redid the trans harness and the alt/starter harness.
Old Apr 7, 2013 | 10:41 AM
  #482
LGshow19's Avatar
I was wondering about the starter. You routing it the same way?
Old Apr 7, 2013 | 10:46 AM
  #483
joseph143's Avatar
Bot that it helps anything other then looks... But have you routed your harness under the intake mani yet? Everything fits perfect except the factory injector wires... They need to be pulled back out of the loom a bit and then they fit perfect. Looks so much nicer..
Old Apr 7, 2013 | 11:17 AM
  #484
EvoDan2004's Avatar
no its a little different. not part of the maain harness.
i did this a few years ago. it def looks better.
Old Apr 7, 2013 | 03:17 PM
  #485
EvoDan2004's Avatar
Quick question. I just re did my start/alt harness. But as I look at at it I was wondering if I can delete the black fuse that the 3 power wires connect to.
Follow me???
Old Apr 8, 2013 | 06:56 AM
  #486
antilag_200's Avatar
Follow me???
No you can not delete it . ( if it is the one I think you are talking about, as it holds the 100 amp fuse for the alternator)
if you want to delete it, ensure that you have a protection fuse inbetween the alternator power line to the battery. I used a circuit breaker
Old Apr 10, 2013 | 06:46 AM
  #487
06MREvo's Avatar
haha, Dan, I told you to ask Warren! I knew he would know....
Old Apr 10, 2013 | 06:57 AM
  #488
joseph143's Avatar
I actually deleted that fuse a while back with no issues... I even had an issue once where my alternator got a bad signal and was hitting 15/16volts. Havent managed to burn the car down yet but i honestly dont suggest anyone play with fate like i have...
Old Apr 10, 2013 | 02:38 PM
  #489
EvoDan2004's Avatar
what isthe fuse for to protect the battery?
Old Apr 10, 2013 | 03:14 PM
  #490
nollij's Avatar
*assumptions*
Protect the battery from overamping charge from alternator, if alternator gets an internal winding to winding fault or if there is a fault on the line going from the battery to the alternator.
The second of those is most likely to occur.
Old Apr 12, 2013 | 07:46 AM
  #491
ExtremeDSM's Avatar
How is the wiring coming along? I remember doing wiring weight reduction years ago on one of my DSM's. In the end, I had no power windows and something else did not work. No idea where I went wrong. I think I may start one of these days on mine but I will be starting from the back to the front.
Old Apr 12, 2013 | 09:38 AM
  #492
EvoDan2004's Avatar
Wiring poject is done. I am just waiting to get the car together to see if it works or not. I did not go crazy with it. I kept it very very simple and only removed what was not plugged in or used. Otherwise it was left alone. There are pics here on the other page before this one.
Old Apr 12, 2013 | 09:41 AM
  #493
badev0's Avatar
Thats exactly what I did also. I think its a safe route to take if you aren't up for doing something like Warren (antilag_200) did. I saved the most weight with the damn abs harness lol.
Old Apr 12, 2013 | 11:18 AM
  #494
ExtremeDSM's Avatar
I thought you were going a little further than that. Hopefully everything works right. Nice thing about the RS, no abs crap to remove.
Old Apr 12, 2013 | 11:36 AM
  #495
EvoDan2004's Avatar
I wanted to go nuts with it. I bought a chase bay harness and was ripped off big time. I ended up buying a new RS harness and just did what I did to it. That is enough for me. Ha
