A Few Upgrades... FF Comp Turbo, JM Fab, 4inch downpipe
Old Jan 2, 2014 | 07:06 PM
  #46
RussellDaniel's Avatar
Amazing!
Old Jan 4, 2014 | 09:55 PM
  #47
way2qik's Avatar
Originally Posted by d-bo
Beautiful car.
Do you think the Dual Radiator fan will help a lot? I have wondered about doing that if i ever switched to a FF setup and if it would actually help. Do they both blow air thru the radiator out of the car? or are they set up differently ?
Yes, it helps. I ran this radiator/fan setup all last season. Both fans blow from front to back.
Originally Posted by RussellDaniel
Amazing!
Thanks!
Old Jan 5, 2014 | 09:06 AM
  #48
DDATuned's Avatar
Looks GREAT bro! Nice work. In for the numbers
Old Jan 9, 2014 | 12:02 AM
  #49
GDChoi's Avatar
massive
Old Jan 9, 2014 | 01:35 PM
  #50
way2qik's Avatar
Hoping to get the car on the dyno in a few weeks. Weather stinks right now...
Old Feb 25, 2014 | 05:11 PM
  #51
JGNERAEVO9's Avatar
What size Comp Turbo is this?
Interesting to see your running dual rails.
Old Feb 26, 2014 | 01:35 PM
  #52
JGNERAEVO9's Avatar
So Edward Snowden gonna tell us the specs? Bahahaha
Old Feb 26, 2014 | 03:30 PM
  #53
way2qik's Avatar
I didn't even see this post until just now. LOL.
Its a Comp 7475
Old Feb 26, 2014 | 03:32 PM
  #54
way2qik's Avatar
Why is that?
Old Feb 26, 2014 | 05:27 PM
  #55
JGNERAEVO9's Avatar
I picked up the Comp 7475 CT43 frame. That looks like CTX5 though they customized it to fit in that frame? My fuel setup is going to be AeroMotive Pro Series pump with 4 x 2150cc FICS. Should be OK past 1200HP including NOS. Why'd you go dual rails? What injectors?
Old Feb 26, 2014 | 05:58 PM
  #56
way2qik's Avatar
If you make 900+ on a Mustang dyno you will be at the edge of what those injectors flow on e85.
Old Feb 26, 2014 | 07:57 PM
  #57
JGNERAEVO9's Avatar
You have 8 x 2150cc? What gear you running in the block and head?
Old Feb 27, 2014 | 02:36 AM
  #58
way2qik's Avatar
I'm sorry, but I don't have a gear in my block. Your car must be different than mine. LOL
Old Feb 27, 2014 | 02:41 AM
  #59
way2qik's Avatar
BTW, that fuel pump will never support 1200awhp especially if you're running e85. It may make 1200 crank hp, but you will have to run the fuel pressure so high on a single set of injectors that the pump will lose volume. I had one of those pumps in a 900hp Turbo TA and they flow well until about 75-80psi at which point they fall off big time.
Old Feb 27, 2014 | 10:29 AM
  #60
JGNERAEVO9's Avatar
What fuel setup you running in the Evo what pump? According to AeroMotive it flows 1700HP forced induction at the engine. I'd say they mean on pump gas so 1100 AWHP on E85. I might need the second set of rails most likely but the pump can handle it. It would most likely reach 1100 HP with a 100, 150 shot of NOS.
