My Carrera White Evolution VIII GSR
Old May 24, 2014 | 08:27 AM
  #31
xXANCHORMONXx's Avatar
Here the crank is getting lightened, strengthened and balanced. You can see some internals in the first pic.
I got my break in oil as well as the oil I'll be running once the motor is broken in.
Old May 24, 2014 | 10:27 AM
  #32
mitsubeastlee's Avatar
dope i didnt know amsoil made break in oil
Old May 24, 2014 | 12:00 PM
  #33
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by xXANCHORMONXx
Old May 24, 2014 | 09:06 PM
  #34
Snake oil
Old May 24, 2014 | 09:07 PM
  #35
Good **** noah
Old May 30, 2014 | 10:53 AM
  #36
So it begins....
Stripped the interior to bolt in the cage
Fitment was spot on, it is an Autopower roll bar with custom plates under the main hoop.
Stripped the firewall. Lots of cleaning. Also removed the ac evaporator.
Here's the beginning of the wire tuck, just taking it all apart.
Got my dash wrapped in suede. Should help keep the sun out of my eyes.
I did some small rust removal on the radiator support and engine bay prep for paint.
Crank is balanced and lightened.
Old May 30, 2014 | 01:38 PM
  #37
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Dash wrap is choice, I do hate the sun that comes off of the dash lol
Old May 30, 2014 | 04:13 PM
  #38
IzzyRS's Avatar
Awesome job on that dash!
Good luck with the build.
Old Jun 2, 2014 | 05:57 AM
  #39
NJ9MR's Avatar
FCOTM Winner
Great job and patience! With the dash wrap, will that effect the air bag at all? Keep up the great work! It's worth it in the end!
Old Jun 2, 2014 | 10:05 AM
  #40
evoforstevo's Avatar
My heart dropped at seeing that valve cover....but it looks like it went to a great home.
Nice build dude!
Old Jun 2, 2014 | 06:20 PM
  #41
looking fantastic bro! the bay looks 10x better
Old Jun 3, 2014 | 07:29 AM
  #42
Yes it probably would. I have my entire seatbelt and airbag system removed since I am running a 6 point harness with HANS.
Thanks guys!
More updates soon
Old Jun 13, 2014 | 09:23 AM
  #43
Here are a few updates
Block being honed.
For whatever reason the Evo does not come with a dowel pin. Since this a stroker and the rotating assembly is being balanced it is critcal that the flywheel and crank can lock into place without play.
My machinest made a dowel pin to make it lock.
Upgraded the front suspension
whiteline 25mm sway
Perrin PSRS
Whiteline adjustable end links
Cusco adjustable end link mounts
Here's a close up of my new wiring.
Engine bay being reassembled. Abs polished and cleared, booster repainted etc
Brakes mounted
Lots of stuff coming in. Shortblock should be done this weekend.
Head was shipped by curt today.
TRE should be finishing my tcase and trans up today.
Old Jun 15, 2014 | 04:36 PM
  #44
That dowel pin idea is interesting and if that works out long term I might do the same!
Old Jun 15, 2014 | 06:56 PM
  #45
bstgsr's Avatar
Car is looking good. I'm throwing around with the idea to build and 8 or 9 myself. Keep up the good work
