So I should have bought an Evo...
Old Jul 19, 2014 | 09:23 PM
  #46
galantman03's Avatar
Originally Posted by sblvro
nice G, you need some serious tires though?
Yeah only running 8inch with a 235, I would like to run a 285 LOL but thats major modfications, hence the cheapest 10.5 +15 rim I need since this will be a long process. I have to redesign the rear suspension to make it work, but it will be worth it for the hook up on launch
Originally Posted by EvoGSR8
Wow amazing build... I don't usually comment on anything but mad props to you! Front end is looking mean!
Thanks man. Its really hard to get it to look right in the pics, but they turned out great
Originally Posted by project_skyline
I never re-torqued mine and 95 has done fine so far up to 36+ psi. I wouldn't worry about them.
I ended up re-torquing them to 95 ft lbs, and they were loose, so I either did it at 85 ft lb the first time or something but they all good now.
Old Jul 20, 2014 | 06:48 AM
  #47
Ken Zaraki's Avatar
Nice car man. Always had a thing for 4 door performance cars. I had a 92 maxima se that was built.so many dropped jaws.
Old Jul 20, 2014 | 10:13 AM
  #48
khan_man's Avatar
Cool ride
Old Jul 20, 2014 | 12:15 PM
  #49
Animefreak1983's Avatar
Cars like this are what made me appreciate the gallants . Before I thought they were old people cars but I've seen some sweet ones over last couple years
Old Jul 21, 2014 | 03:25 PM
  #50
Dude believe it or not, I have moms(like hot ones) compliment me on the ride... They find me! If I could have that much luck with women my age(25) lol. One even asked for a ride with her kids in her car! SMH
Originally Posted by khan_man
Cool ride
Thanks bro
And thats why I built it. People always gave me crap for the "grandma car" now this thing is built to eat up some vettes and sportbikes. My next galant I want to drop a v8 in it and have it rwd. some time...
Old Jul 27, 2014 | 05:50 PM
  #51
Originally Posted by galantman03
Also, I have an aem twin fire ignition box with a spooling up cop, not installed yet because of some starting troubleshooting issues lol. But the settings on the AEM box to run from the evo 8 ecu, what do I set them to?
does anybody know the above info? like rising edge or falling edge... ect
Old Jul 30, 2014 | 01:40 PM
  #52
hey guys need some help on this issue.
As soon as I turn the car on, SES light is on. It's been driving fine, but I have 2 codes, and each record twice on the scanner, and even it clears the moment I turn the key off, and if I turn it back on they are right back up.
I have
P0325 Knock Sensor 1 Circuit
The knock sensor has the signal wire and the ground shielding around it. WFT can be the issue? Anybody know how to test a knock sensor? I.E. Resistance or something
P0110 Intake Air Temp Sensor 1 Circuit
I have been converted to SD, so what is this from? I have a AEM 5 bar, is there any way that a bad sensor could cause this code? I'm going to meter the wires for everything right now, but the IAT is resistance based correct?
Need some ideas because the moment I hit 0 on my boost gauge car leans out so bad it starts cutting out. And before anybody asks, both fuel pumps and relays are good, and I manually tested my FPR to 30 psi with an air compressor, and my fuel pressure goes to 70 psi... I'm racking my brain here...
Old Aug 3, 2014 | 04:59 PM
  #53
Nobody has any info as to what could cause a IAT sensor 1 circuit code, when the sensor is good and the outputs ohms to the ecu? I'm leaning towards an ecu issue.... Anybody have any knowledge on what the P0325 code actually means?
LUNARFX
Outlander Sport
20
Jul 16, 2018 05:40 PM
cficare68
Aug 26, 2016 06:45 PM
cficare68
Mar 16, 2016 09:26 PM
prack7
Jul 13, 2015 07:11 PM
hinduboy74
For Sale - Miscellaneous Automotive
Oct 30, 2013 05:45 AM
