Long Time Coming Stroker Build
Old Feb 27, 2016 | 02:57 PM
bryanf's Avatar
Hello all,
I've been wanting to do a build for sometime now but between getting out of the military, going back to school, and planning a wedding my car had taken a back seat for a long time. Now that school's coming to a close and the wedding is all planned out/paid for I can focus on working on my car a bit. My goals were to build a fun street car that I can drive from time to time without having to worry about much. I also wanted to add some suspension parts along with a few other little changes while the car was down. The following will be done or is already done to the car.
Head:
-Valve Job
-Kiggly Springs and Ti retainers
-GSC S2 Cams
-New valves, lifters, etc
-ARP L19 head studs
Block:
-2.3l
-Manley Crank
-Manley Rods
-ACL Bearings
-Weisco 1400 HD Pistons
-All new hardware'
-OEM Stubby Balance shaft Eliminator
-Fluidampr
Suspension:
-Bilstein shocks (Re-valved/built)
-Swift springs
-All new bushings
Fuel:
-FIC 2150 injectors
-Double Pumper (Walbro 255's)
-All new Fuel lines
Turbo:
-FP Red (For now)
-FP oil line kit
Random stuff:
-ARP extended studs
-New AEM Guages
-New floor mats
-Get new upper intercooler pipe fab work
Block at the machine shop
Pistons
FP Red (Purchased on the forum)--Upgraded due to member lying about the condition
Table of goodies
Bilstein's being packed up to get a re-build
New FAP and filter for FP oil line
Fluidampr
Much more to come!!
Bryan
Old Feb 27, 2016 | 10:29 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Nice! Another solid SoCal Evo!
Old Feb 28, 2016 | 12:34 AM
bryanf's Avatar
Thank you!
Old Feb 28, 2016 | 12:40 AM
bryanf's Avatar
Turbo needed to be taken apart and inspected for any issues and FAP installed. The Retaining clip proved to be a big pain in the A**!!!!!
All done!
A package came in as well with some goodies.
Old Feb 28, 2016 | 01:17 AM
roni4g63's Avatar
nice build man, goodluck, just finished pulling my motor today, my process is just starting..
Old Feb 28, 2016 | 09:59 AM
bryanf's Avatar
Thank you Roni. This build actually was a lot of fun and I didn't have that many hiccups while doing it. I guess when your not in a rush it's much easier.
Bryan
Old Feb 28, 2016 | 05:32 PM
roni4g63's Avatar
yes Bryan I agree, this will be my first time building a 4 banger by myself, I have built small block 350's before, so I am familiar with blueprinting and assembly techniques, this is a project car as I have a daily driver, so I am in no rush. In fact, I will likely send my trans and tcase out to shep to get a stage 1 rebuild on both while everything is out. what crank did you use? forged? I am thinking about the manely billet for this build. also, did you overbore the block? what HG did you end up using? thanks Bryan.
Old Feb 28, 2016 | 06:30 PM
bryanf's Avatar
An engine is an engine, as long as you take your time, triple check everything, and walk away when things get frustrating it'll be a breeze. The next in line to be upgraded will be the driveline on my car and will be using Shep as well. I'll enjoy the car a bit before I tackle that project though.
My crank option was the standard Manley 100mm crank. I was on the fence with going billet but decided to go with the standard crank because my power levels won't go above 600-650 ever (I hope). I said to myself that if I start to go any higher it might be time to look into another platform to tinker with. I'm going to build my spare engine once this project is done, so who knows what ill do. As for 'Overbore" I had to only go .02 over once the machine shop did their work. If you're going 2.3L just make sure you get the stroker pistons and you'll be good to go. The head gasket I went with is the standard OEM gasket as from what I've read and heard they hold up well. Depending if I stay with the FP Red or upgrade to the FP Black, I'll stay around the 30-35lbs of boost in which I think the head gasket should be just fine.
Old Feb 28, 2016 | 06:35 PM
bryanf's Avatar
Here's some pictures from when I got my intake/exhuast manifolds and throttle body back from porting and coating. Socalporting.com did an amazing job and the price was to good to pass up. My turbo will go out once I decide if I'm going to keep the Red or go Black and coating will be applied.
Intake Manifold all ported and coated up
Exhaust manifold
Old Feb 28, 2016 | 06:45 PM
bryanf's Avatar
Some more pictures of my fuel system which was not fun installing all the new lines. If I could go back and do it over again I would build this myself instead of buying a kit from here. It turned out really nice but I feel that I could have made the line's a bit cleaner for fitting purposes. The fuel lines were also hare to remove.
Old unit:
New unit:
FIC 2150's
Old Mar 1, 2016 | 09:01 AM
bryanf's Avatar
Here's the block and head back from the machine shop and put together. I didn't get any pictures of me assembling...ohh well!!
Old Mar 1, 2016 | 10:25 PM
Jonno99's Avatar
This is like something I'd like to do with a DIY build, how much do you think you save by doing this yourself? Is it just basically the machining you need to get done and everything else you can do yourself?
Old Mar 1, 2016 | 11:08 PM
bryanf's Avatar
At the start of the build I was planning on doing it myself to save but all said and done you don't really save anything. It's also possible you spend a bit more to be honest. I'm glad I went ahead and did it this way because it turned out to be a fun project, although very challenging at times because I did the whole thing myself. You have to not only factor in the machining (don't go cheap on this!) and parts but also the tools, gauges/micrometers, ring file, dial bore gauge, etc. If you have all the tools because you've done builds before then you might come out saving a small amount but honestly it'll still be pricey. Just remember to buy good guages because it really make a difference between bottom shelf brands and upper shelf brands.
Bryan
Old Mar 8, 2016 | 01:34 PM
bryanf's Avatar
Car was put to sleep and the engine removal started!! This proved to be a little difficult because I did it by myself. I would say, honestly, that marking everything and writing it down in my book is what took the longest but paid off when reinstalling everything.
First day at work.
New VS old
Second day and wala its out!!
Side note:
For anyone doing this for the first time, make sure you pull the front bumper off to give some more room for the lift. I didn't do this and it made it very difficult to get the engine out. I fixed this when installing the engine and it proved to make it much easier and less stress on scratching things.
Bryan
Old Mar 8, 2016 | 10:16 PM
roni4g63's Avatar
First day
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1085.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1085.jpg" border="0" alt=" photo IMG_1085.jpg"/></a>
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1086.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1086.jpg" border="0" alt=" photo IMG_1086.jpg"/></a>
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1089.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1089.jpg" border="0" alt=" photo IMG_1089.jpg"/></a>
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1843.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1843.jpg" border="0" alt=" photo IMG_1843.jpg"/></a>
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1845.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1845.jpg" border="0" alt=" photo IMG_1845.jpg"/></a>
New VS old
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1849.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1849.jpg" border="0" alt=" photo IMG_1849.jpg"/></a>
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1111.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1111.jpg" border="0" alt=" photo IMG_1111.jpg"/></a>
Time to clean this thing up
<a href="http://s100.photobucket.com/user/kwtr/media/IMG_1112.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m14/kwtr/IMG_1112.jpg" border="0" alt=" photo IMG_1112.jpg"/></a>
Side note:
Bryan
+1 on not cheaping out on machine work, proper 4g63 boring requires a torque plate along with the studs being used an hg installed. I am also getting my crank, rods and main bearings, pistons, pins and all rings WPC coated, I feel like this will be a great benfit both performance wise and longevity vise.
