2003 Evolution project HELP
Old Apr 8, 2016 | 08:01 AM
Tyler121596's Avatar
what evo engine is this?? and what are the common TO least common issues for this engine not starting because this one will not or this one will not start. Need help and diagnostic help from you guys! Experts.. thats a picture of it please let me know if you can't see it !!!!!!
Old May 3, 2016 | 05:46 AM
N8vEvoVIII's Avatar
Cam sensor , crank sensor, and fuel pump are big issues, but first check to make sure you are getting fuel & spark.
If your getting fuel pressure then fuel pump eliminated.
I am not sure if cam sensor and crank sensor can cause a lack of spark. I'm sure it does tho.
Is the car throwing any codes?
Big culprit and the one you don't want it to be is a busted timing belt because these are interference motors.
But what happened did it just stop running? Was it acting up blowing white smoke any other details
Old May 3, 2016 | 08:09 AM
Ev0ikon's Avatar
If you could trailer it (about 2 hours) to Birmingham, AL area I'll help you identify the problem.
Old May 3, 2016 | 05:54 PM
Fast_Freddie's Avatar
Veteran: Navy
Ignition fuse under the dash as well... easiest
purpledranktown
Lancer Engine Management / Tuning Forums
Mar 30, 2014 05:49 PM
purpledranktown
Lancer Engine Tech
Mar 10, 2014 05:33 PM
ww04
For Sale - Cars For Sale
32
Jun 13, 2010 09:22 PM
Go_Lancer_Go
17
Mar 9, 2006 02:54 PM
CBRD
May 17, 2005 06:32 AM
