The Make Beli-evo
Old Jan 26, 2018 | 12:19 AM
Murkrow's Avatar
The Make Beli-evo
Hopefully you die hard evo guys won't get offended from my thread title But here's my build - an 03 Eclipse GT. I can proudly say it's the fastest and most powerful auto 3g in recorded history! Recap of events (updated accordingly):
Nov '14 - purchased car stock with seized engine
Nov '14 - swapped in non-MIVEC 6G75 engine
Dec '14 - dyno'ed 222hp/236tq
Apr '15 - ran my first 14sec pass (14.2 @ 90)
July '15 - converted to AWD
Aug '15 - Vortech supercharger
Sep '15 - ran my first 13sec pass (13.1 @ 103)
Nov '15 - FrozenBoost water to air intercooler setup
Feb '16 - dyno'ed 301hp/301tq
Mar '16 - removed supercharger and turbo'd
Apr '16 - dyno'ed 370hp/410tq
May '16 - ran new best pass (12.1 @ 114)
Sep '16 - blew up stock engine #1
Oct '16 - ran my first 11sec pass (11.7 @ 117)
Nov '16 - blew up stock engine #2
Apr '17 - swapped in built MIVEC 6G75 engine
Jun '17 - ran new best pass (11.2 @ 128)
July '17 - bearing failure in trans
Sep '17 - rebuilt trans, new turbo kit, larger turbo
Nov '17 - dyno'ed 713hp/668tq
Jun '18 - ran new best pass (10.9 @ 138)
July '18 - rod bearing failure
Aug '18 - rebuilt trans, new turbo kit
Sep '18 - ran new best pass (10.6 @ 138)
Sep '18 - dyno'ed 789hp/767tq
Apr '19 - new turbo kit, larger turbo
Aug '19 - rebuilt trans, changed 3.73FD to 4.31FD
Oct '19 - back to 3.73FD, ran new best trap speed (139)
Best time slip
Best dyno sheet
The current mod list as of 4/30/20 that's updated as it progresses.
Engine:
MIVEC 6G75 swap
JE 9.9:1 1mm over pistons
3SX rods w/ ARP2000 bolts
King rod bearings
King main bearings
ARP main studs
H13 1/2" head studs
ARP insert washers
Mild port heads and resized bowls
Pampena Motorsports head-lift fix
Cometic .051" head gaskets
Comp Cams valve springs
Chromoly valve spring locators
GSC valve stem seals
Web Cams custom grind cams
S90 Evo 8 throttle body
Prothane side engine mounts
Billet front and rear roll stops
Billet crossmember bushings
EVAP/EGR/Cats/O2 sensors deleted
Custom oil catch can (dual 8AN inlets, baffled, vented)
Mishimoto full-size radiator w/ stock fans
Stainless 2qt coolant reservoir w/ 4AN inlet
Turbo:
BorgWarner S372SXE 72/73
Treadstone TR1245 4.5" intercooler
Precision 66mm wastegate
Synapse Synchronic BOV
Custom stainless vband hot side piping
Aluminum 2.5" intercooler piping
Mishimoto couplers and T-bolt clamps
3" stainless vband downpipe
All back-purged TIG welds
3AN oil feed/12AN oil drain
Transmission:
AWD conversion
Custom Endeavor/9G Galant auto trans
Billet accumulators w/ dual seals
Higher rate accumulator springs
Raybestos stage 1 friction discs
New seals and steel plates
Oversized pressure and reaction plates
Modified valve body (ported restrictors and higher line pressure)
Precision stock stall 600hp converter
30 row 288 cu. in. trans cooler
7" trans cooler fan
6AN cooler lines
Transfer Case:
Evo 6 transfer case
MFactory Evo 4-6 front helical LSD
Evo 8 front axles and stub shafts
Mitsu SAE 90 LSD gear oil
Differential:
GSX diff housing
MFactory Evo 7-9 rear helical LSD
Evo 8/GSX rear axles
Custom 2 piece driveshaft
Frontline Fabrication billet diff cover
Split Motorsports billet diff bushings
Fuel/Spark/Tuning:
GSX Full Blown double pumper
Walbro 525 pump
8awg leads to fuel pump(s)
Dual 6AN feed/6AN return
6AN 100micron fuel filters (one per rail)
75 fuel rail with 6AN fittings
Aeromotive A1000 fpr
FIC 1650cc injectors
MSD 6AL module, tach adapter, window switch, and Blaster SS coil
NGK plugs and wires
GM 3" MAF and MAF Translator
Dual ecu setup and big maps
Tactrix 2.0
EvoScan
Interior:
Bride front seats
Stratus RT brushed nickel center console
Stratus RT brushed nickel door panels
Autopower 4pt roll cage
AEM TruBoost gauge
AEM AFR gauge
AEM oil pressure gauge
AEM coolant temp gauge
Prosport IAT gauge
Prosport fuel pressure gauge
Prosport trans temp gauge
Glowshift triple gauge pillar pod
LED interior lights (cluster, hvac controller, clock pod, mirror, glove box)
Mitsubishi navigation radio
Plate mounted backup camera
Kicker 6.5's and 6x9s
Kicker 500.1 amplifier
Sundown SA-8v2 subwoofer
Fuse box relocated under dash
Battery relocated to trunk
Jegs push-off killswitch
Moroso sealed battery box
T-Spec fused distribution block
XS Power lightweight AGM battery
Exterior:
Depo Euro projector headlight housings
Depo front and rear turn signal housings
TYC gen 2 tail light housings
LED low and high beam bulbs
LED brake, turn, and reverse bulbs
Redline Tuning hood struts
Suspension:
K Sport Kontrol coil overs
ES front lower control arm bushings
Moog rear camber adjustment kits
ES rear knuckle and upper control arm bushings
Torque Solution rear subframe bushings
Megan Racing rear toe arms
Brakes, Wheels, and Tires:
Front Endeavor calipers
Rear Brembo Evo 8 calipers
Apex SS lines
Mitsu DOT4 fluid
PowerStop ceramic pads
PowerStop drilled and slotted rotors
Locking tuner lugs
15mm rear wheel spacers
17x9 +35 Enkei RPF1 wheels
Nitto NT05R 275/40R17 tires
Weight Reduction:
Fog lights removed
56lbs of padding and insulation removed
AC compressor, bracket, lines, condenser, and evap core removed
Spare tire, jack, tools, and trunk brackets removed
Stock battery tray and bracket removed
Exhaust hangers, brackets, and heat shields removed
Washer fluid reservoir and pump removed
Core support bumper brackets removed
Fuse box bracket and stock engine grounding bracket removed
PS rack heat shield removed
Cruise control box removed
Hood bracing removed
Front crash bar removed
Front sway bar/links removed
More pictures
It may not be an evo but at least it's awd and turbo!
Old Jan 26, 2018 | 03:42 AM
s.e.a.n.'s Avatar
Crazy setup!
Old Jan 26, 2018 | 10:22 AM
LetsGetThisDone's Avatar
What are you using for the trans/tcase/rear diff?
Old Jan 26, 2018 | 05:15 PM
Murkrow's Avatar
W4A5A trans, evo 4 tcase, and 2g gsx diff
Old Jan 26, 2018 | 05:41 PM
FwdtoAWD's Avatar
Veteran: NavyVeteran: Marine Corp
Awesome car!!! Glad to see the 3g getting some love.
Had the exact same year and color eclipse only it was a GS. Ran low 15s stop quick for a non-turbo 4 cylinder car. Loved that car considered doing exactly what you did awd conversion with an evo platform and turboing the 4G64. But kids came and I thought I need a car with four doors. Sold it and got a evo 8 spent all my time/money rebuilding that.
The 3g eclipses really don't get any love from the tuning community, but they are great cars. Glad to see there is still love for the eclipses.
Old Feb 7, 2018 | 01:56 PM
Murkrow's Avatar
Originally Posted by s.e.a.n.
Crazy setup!
Thanks!
Yeah they have a ton in common with other mitsubishis in similar years. They get tuned the same, many of the same parts fit or can be adapted, etc. Yeah the 4cyl 3gs are simple to make awd and turbo. I considered doing the swap for a fun daily. All the same parts are used to convert the v6 to awd besides the trans!
Old Feb 7, 2018 | 02:00 PM
Murkrow's Avatar
I was checking over my pre-turbo piping and noticed some carbon build up around the tube for the wastegate. Turns out the piping cracked and needed to be rewelded. My buddy fixed it and added gussets to prevent it from happening again. It came out pretty good! I plan to have the pre-turbo piping ceramic coated before spring to keep engine bay temps down.
Old Feb 10, 2018 | 06:25 PM
WWGSR's Avatar
Any vids of this thing
Old Feb 21, 2018 | 01:08 PM
Selena_2000's Avatar
Veteran: Navy
<3!!!! this makes me miss my 3G sooo bad!!! i had a 4g64, and was in the process of a turbo awd build on her too before life took over and threw a wrench in that. i still have a soft spot for these things even now that i have my evo. SO glad to see the 6g75 getting some lovin' too
Old Feb 22, 2018 | 10:33 AM
Pal215's Avatar
OP, you've done an AWD conversion, an engine swap, and you're making more than 700hp, how can we be offended? This car is awesome! Nice work and congrats on the latest time slip. 3.8L AWD V6 ? Is it possible to convert to a manual if you wanted to? If so, what trans would you use?
Old Feb 22, 2018 | 02:13 PM
Murkrow's Avatar
I have a video on Facebook. The embed iframe links don't seem to work on this forum though and it won't let me download to upload elsewhere.
https://www.facebook.com/alex.brodskyyy/videos/10210907780623468/
Tbh I love the way these things look. It's just the lack of power and aftermarket support that drives people away. If they had an AWD turbo option it would have been a respectable car. At least for the 4cyl 3G's it's really simple to convert to that
Hey thanks man! And you never know; I've been given a lot of **** over the years from DSM and Evo owners so I needed a disclaimer Yeah 3.8L AWD. The 3000GT AWD manual trans bolts up but it's on the wrong side of the engine bay. Only option is a custom bell housing or adapter plate with an Evo trans. I've thought about going manual but the car is already fun and I'd rather put that money into other areas of the car.
Old Feb 22, 2018 | 08:04 PM
evo8tx's Avatar
crazy car but definitely a monster lol first 1 ive even seen actually done so hats off to you.
Old Feb 23, 2018 | 09:55 AM
Pal215's Avatar
Right on man
This thing must be a blast to drive. Good to know there are options out there. Hopefully your build will motivate more people to do this. So much potential here.
Old Feb 24, 2018 | 03:14 PM
Murkrow's Avatar
Thanks! It's been a huge learning experience to say the least. Made me realize how many headaches could have been avoided by doing things right the first time
Right on man
I hope it does too. There's been a few other turbo 3G's but I've never seen another noteworthy auto. I'm always open to giving info on my build! And when the roads clear I'll be trying to break some more records and have quite a few more updates to post
Old Feb 24, 2018 | 07:33 PM
Murkrow's Avatar
After doing some disassembling I've converted my stock auto rom to "big maps" and found the 2 byte load and airflow values (no need for 2 byte rpm since I don't rev that high). Can anyone with more experience verify my 2 byte values? TIA
80940003 rom:
6a0a 6a0b Load
6a66 6a67 Airflow
