Ayoustin
close
- Join DateJul 2014
- LocationSC
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:648 Times in 468 Posts
Quote:
excellent info!
do you happen to know if 4G63 head builders recommend enlarging the combustion chamber diameter to fit the 86.5mm bore better?
I don't know what others recommend but I would not. You end up lowering compression and the area you open up is one of the least active areas of combustion.Originally Posted by Strm Trpr
excellent info!
Quote:
excellent, thank you for the info!Originally Posted by ayoustin
Quote:
excellent info!
yes it’s a good idea to radius the sharp edge out to the bore size it will prevent hot spots.Originally Posted by Strm Trpr
excellent info!
Quote:
Thanks man, I look forward to see how it will be.Originally Posted by 2winscroll
Looking good!
Should be one heck of a Street Beast!
Hoping to stop the car and make the engine change within the end of the year
Quote:
Last year I ran through all the calcs for where the best improvements could be made and the stock intake size is fine for any engine using a bore smaller than 87mm. The exhaust would benefit slightly from a +1mm valve but it's not necessary. You'll gain WAAAY more with a good port job vs larger valves.
Sean is correct, if you're going to run oversized valves, go with larger exhaust valves. There's math involved but it boils down to valve/bore ratios and your intake/exhaust ratio. If you run a massive valve on a small bore you're going to shoot yourself in the foot because the valves get so large that the air has a tough time getting around them to get into the cylinder.Last year I ran through all the calcs for where the best improvements could be made and the stock intake size is fine for any engine using a bore smaller than 87mm. The exhaust would benefit slightly from a +1mm valve but it's not necessary. You'll gain WAAAY more with a good port job vs larger valves.
Quote:
Thanks a lot guys for all your advices.Originally Posted by letsgetthisdone
Because that has what has been proven to be needed. For the power goal you stated, there isn't a need for any oversized valves...
Unfortunately I've been out for weeks and had no news from the mechanic.
I never put in doubt these choice, because he is 4G63 expert with tens of builds behind.
But I try to meet him tomorrow just to fix this point, because if this is proven I would follow it.
Let u know soon
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
iTrader Feedback Score(1)
Liked:1,629 Times in 1,392 Posts
It's not the end of the world if he already did both. More just extra money that didn't need spent.
