Perrin PWI-1 Water Injection System************
STILL AVAILABLE!!!!
I have a NEW IN BOX Perrin Progressive PWI-1 Water Injection System up for sale.
Its a pricy kit but it is arguably the best kit available.
Offer up if you are interested.
Thank you..
if you need some info on the kit here is a link.
http://www.hptmotorsports.com/perrin...ion_system.php
Thank you..
thanks for the bump, but I have never seen this kit that cheap...
can you please provide a link or something?
the pw1 is suppose to be $700 meth kit (give or take a little) I usually see it for $800 now days..
if you can find it that cheap that's damn good...
but I'm just asking for offers right now.
thanks!
thanks!
http://performance.************/perr...0/i-60931.aspx
we must be looking at different things..
I found it on there for $899 regular price and $710 member price?
Images May Not be Vehicle Specific. For Display Purposes Only.
Product Description
The PERRIN PWI-1 water/methanol injection system is designed to suppress detonation caused by high intake charge temperatures and or when the effective compression ratio has been taken beyond the auto ignition point (of fuel) by increased boost from a turbo or a supercharger. To suppress Detonation, a fine mist of a mixture of water and methanol is injected into the intake charge. Water, with its high latent heat content, and methanol, with its high octane rating, are extremely effective at controlling the onset of detonation. From this you can gain power from increasing timing, or leaning the engine out, or simply add a large margin of safety to your engine.
By adding an extremely fine mist of water you can effectively add an additional intercooler to your vehicle. This lowers charge temperatures, reduces any tendency for detonation, and thus greatly improves horsepower and torque. Most clients will see gains in excess of 20WHP once tuned for! All while increasing safety and longevity of the engine.
The PERRIN Performance PWI-1 Water Injection System includes everything you need for a professional installation. Simply provide your own bucket of water! With a dash mounted control and display you can activate or deactivate the system as well as monitor the water level, flow and perform tests of the entire kit. Additionally, the PWI-1 brain uses trim pots to adjust flow, and injection start. The brain incorporates several safety functions, which can detect when the nozzle is blocked, or water is low in tank. If this happens the PWI-1 brain can be set to cut boost, switch to a different map (ECU dependent), or turn on a light or any number of things you can come up with. These are features simply not found on other water injection systems. Easy to assemble and install.
Includes hoses, mounting hardware, instructions, and tuning tips.
Place Order Here
Part #:
ASM-ENG-900
Notes:
Progressive Water Injection System
MSRP:
$ 899.00
Member Price: 710.21
This special price is available to YoParts members only! Signup Toda
Product Description
Place Order Here
Part #:
ASM-ENG-900
Notes:
MSRP:
$ 899.00
could be? who knows. I wish I would have bought it at that price! I've never seen $200+ off on this kit.
anywho..
still available!
make some offers on this bad *** meth kit!
anywho..
still available!
