FS: Short Route UICP and Drop In Filter
Old Mar 4, 2009 | 09:17 PM
jid2's Avatar
I've got my old IC pipes I'm looking to clear out, I built new ones when I changed my setup. These are stainless steel and require a small battery as they take the short route to the intake manifold. These are the pipes, a BOV hose, and the coupler which goes between the pipes (just found it, it's not in the picture) - you will need to supply the coupler to the throttle body and clamps. You can get on on ebay for $10! I ran 26+ psi with T-bolts on these for 3 years including track days and never blew a hose.
Price $149 shipped
Here's a picture of them installed on my car.
Filter - sold
Old Mar 5, 2009 | 08:12 AM
jid2's Avatar
I found the coupler which goes between the pipes, and you can reuse the stock coupler at the IC, so all you need is the coupler at the throttle body, which is a 2.75" to 2.5".
Old Mar 5, 2009 | 01:52 PM
jid2's Avatar
Both still available.
Old Mar 5, 2009 | 09:30 PM
jid2's Avatar
IC pipes buyer fell through - still available.
Old Mar 5, 2009 | 09:43 PM
idriveanevo's Avatar
mig welded? where did you get the pipes?
Old Mar 5, 2009 | 10:05 PM
jid2's Avatar
They're TIG welded, I built them.
Old Mar 5, 2009 | 11:41 PM
ok, i just ask cause im just tryin to compare to others of similar price. thanks!
Old Mar 6, 2009 | 07:54 AM
jid2's Avatar
Friday bump-ola. These are packed and ready to go now, someone needs these.
Old Mar 6, 2009 | 09:20 PM
jid2's Avatar
Sale pending on the filter. IC pipes still available.
Old Mar 9, 2009 | 12:23 PM
jid2's Avatar
Filter sold.
IC pipes still up.
Old Mar 11, 2009 | 10:05 AM
jid2's Avatar
Price lowered on the IC pipes. These are identical to the Buschur stuff for the most part.
Old Mar 13, 2009 | 12:31 AM
boostin''s Avatar
Registered User
Question
Hey is that the Apex intake cold air box assembly in the picutres or did you custom make that one too?Thanks!
Old Mar 13, 2009 | 04:27 AM
Levar's Avatar
Veteran: Army
In the picture it looks like there is still clearance for a stock-sized battery tray. Have you confirmed if a stock tray would fit even if with minor trimming? I currently have the Injen UICP set up and I just bought a RFL BOV. I can tell from the picture where the larger pipe runs but what about the smaller pipe? I'm assuming it leads to the FMIC (in which case I have the stock). I do plan on running either the BR Race or ETS 4" FMIC down the road. Any foreseeable problems with either FMIC? Also, could you post the EBay link to where I need to buy the coupler? Bottom line, I'm interested but I need these small concerns addressed before I send you the money. Thanks.
Old Mar 16, 2009 | 09:29 PM
jid2's Avatar
These won't work with the stock battery - no way. Maybe a type 51 battery that is sideways. I can only confirm a proper Odyssey PC680 (everyones small battery kit).
The lower pipe runs right off the intercooler straight to the upper. Like this. same as Buschur stuff. These will work with either the Buschur or ETS IC.
Coupler. http://cgi.ebay.com/ebaymotors/2-75-...Q5fAccessories
Old Mar 18, 2009 | 07:45 AM
jid2's Avatar
Still got the IC pipes.
