FIC 1120 Scalings/Latency
Old Feb 23, 2016 | 03:39 PM
edsct9a's Avatar
I just got some FIC 1120 injectors and would like to see the scaling/latency some of you run on 91 and E85. I looked in the super merge thread but there were only 2 posts on these injectors. Is the included data sheet any help?
Old Apr 22, 2016 | 11:49 AM
turbotaloon95's Avatar
I was just looking for this information myself. I just ordered the FIC 1120's and plan to run e-85 when I get them in. I found some information that may be helpful:
https://www.evolutionm.net/forums/ecuflash/457738-injector-scaling-latency-supermerge-14.html#post11209267 - Post 11209267
https://www.evolutionm.net/forums/ecuflash/457738-injector-scaling-latency-supermerge-14.html#post11205399 - Post 11205399
https://www.evolutionm.net/forums/general-engine-management-tuning-forum/703323-help-injectors-lataency-scaling-aren-t-normal.html
These posts should give you a starting point to get the car to run. Then from there just log your fuel trims and adjust accordingly.
My plan is to swap injectors while still running 93 octane. Once that looks good, I'll switch to e-85 and adjust.
Old Apr 22, 2016 | 03:49 PM
edsct9a's Avatar
Thanks but I figured it out.
Old Apr 25, 2016 | 06:35 AM
What numbers did you end up using? I'm curious because I will be doing this in the next week or so.
Old Apr 25, 2016 | 10:39 AM
edsct9a's Avatar
This is what I have now and the trims are close together on E85. The 975 scaling is for 91 but thats probably off just a bit since I havent ran 91 since I changed my latency.
Old Apr 25, 2016 | 11:40 AM
great, thanks for the info!
Old May 6, 2016 | 07:38 AM
Just an FYI, I used your latency values but set injectors to 1008 on 93 octane and it was pretty close. Idle trims at -12, cruise at -2. Thanks!
Old May 6, 2016 | 07:48 AM
edsct9a's Avatar
Try increasing latency to bring them closer if you want to. Scaling will have to be adjusted as needed.
Old May 6, 2016 | 11:20 AM
Yea I'm fine tuning now, but I started with your numbers and got super close. Thanks!
Old Jun 27, 2017 | 05:16 AM
nicklim208's Avatar
Hi guys. How is ur fuel consumption on normal pump gas? I'm only doing about 14mpg on 98 fuel. Are these injectors v high in consumption or is it my tuning issue?
im running on stock engine with 270 Tomei poncam and FP red.
evo8tanner
Sep 23, 2016 11:31 AM
kaonashi
Nov 5, 2015 08:35 AM
ReidFletcher
Jul 27, 2015 09:01 PM
EvilTechnology
Sep 16, 2014 05:31 PM
FlintownKilla
E85 / Ethanol
Apr 21, 2008 04:18 PM
