Oil threw exhaust Manifold
Hello, Anybody have the slightest idea why i have oil coming out of my exhaust manifold ?
I have zero leaks to the bottom.
New valve cover gasket.
No smoke out my exhaust.
10w30 valvoline vr1 syntetic oil every 2500
fp red turbo, cams, etc......
Runs perfect. idles fine . i am getting a random misfire light wich comes for about 3 days and goes away for another week and comes back by itself. Maybe somebody here can fill me up on this issue . thanks ( i cleaned it before and it got oil again on it )
Ok thanks guys. I appreciate the help and will update after i change the exhaust manifold gasket and put some high temp sealant on the threads . ( Im glad i didnt get a negative comment like, its a seal or something bad off the back ) excellent form.
What Razor said, if the valve cover gasket isn't leaking and oil dripping down from it. I'm going through same thing you are right now, replacing the studs with some sealant because the bottom center one was leaking some oil, made me think the turbo was leaking and smoking, turned out was just an exhaust manifold stud.
Alright for sure ill do that. Ive been driving my Tacoma instead,since i though it was something really bad as to exhaust valve seals or something like that. Im really hoping its the stud.
Yea I removed all the studs with a stud remover, installed new OEM studs with a little copper RTV around last few threads. Others may just use some thread sealant but I used copper RTV. Torqued to 18-20ft/lbs into head. Used Snapon part #MSKM10 to remove and install studs. ARP says finger tighten them, meh, I torqued them in like the old DSM FSM says.
