Car stalls at stop light. idle dip. Won't start without gas
Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
well i ordered an iac so I'll update once it comes in. Would love to know where you found one for 55 bnib though. thats crazy talk
I know this thread is a little long in the tooth but thought I'd shime in with my 2¢.. Not sure if this is same as Mit but it's 12.95 shipped...BUT..I went through 2 cheap ones in under 10K mi....$5 junk yard one has been on for 2 years and about 20K miles.. http://www.ebay.com/itm/NEW-IDLE-AIR...9Uc0cY&vxp=mtr
Reason: correct text
randomevo, et al...I'm going to say it's your MAP sensor....
Identical problems for me, sudden onset of symptoms, car shutting off when idling, pulling into driveways etc., even on the highways when foot off the gas, etc, etc...no codes, running like crap, can't get it started unless foot on the gas/floor, flooded symptoms, etc, etc. Checked everything you've already checked, chasing a ghost it seemed like, until...
I took off the MAP to inspect it, not much to see other than testing it. But before I went that route, the o-ring seemed to be a bit brittle and loose, so went to Ace Hardware and picked up a couple, one the right size and one a gauge larger. Well, if you haven't already anticipated, I tried the larger gauge and ended up busting one of the mounting tabs off. Now I had to spend the $90 or so whether it was faulty or not!
Solution:
After replacing the sensor, the car went back to normal. I hope this solves the issue for you as well!
This sounds like IAC to me. They usually don't just quit, they suffer a lingering death. But if the car bogs while driving at steady speed I'd suspect the O2 sensor.
Car bogging at steady speed is also symptomatic of a failing MAP sensor. It's really tough to pinpoint these driveability issues sometimes that I have resorted to keeping extra sensors/IACV on hand just in case.
