No boost before 6k
No boost before 6k
With a heavy heart i am writing this fellas.
Getting 15 Psi @ 5.8k , 64mm turbo with MAp t3 exhaust manifold -S2s.
Things that i have checked.
-Boost leak
-Exhaust leak
-Bov
-Changed the turbo
-Down pipe
-Checked Cam timing
-Checked with Boost controller disconnected
-Checked the waste gate.
Only thing left is to change the waste gate and use a 1.5 bar spring.
Please advise.
Thanks.
-Boost leak
-Exhaust leak
-Bov
-Changed the turbo
-Down pipe
-Checked Cam timing
Please advise.
Thanks.
At what psi did you check for boost leaks?
Has this issue recently started occurring or after a modification you had done? if so, what was it?
Can you post some pics of the engine bay and parts setups?
You're head is extremely dirty around the exhaust manifold flange. Maybe its leaking there really badly.
EDIT: Well it looks like everything is extremely dirty and you said you checked that so never mind.
Can't find another tsmart 38mm.
looking to swap exhaust manifold. Wgate down pipe. If that disnt work either then the last option left is to change the cylinder head but that would be the end of this chapter. Extremely frustrated.
Deezee
17
Mar 30, 2007 08:21 AM
crasher
10
Mar 8, 2007 10:22 AM
PHiSH
14
Aug 26, 2004 03:09 PM
