No boost before 6k
Old Mar 18, 2017 | 10:55 AM
mines5's Avatar
No boost before 6k
With a heavy heart i am writing this fellas.
Getting 15 Psi @ 5.8k , 64mm turbo with MAp t3 exhaust manifold -S2s.
Things that i have checked.
-Boost leak
-Exhaust leak
-Bov
-Changed the turbo
-Down pipe
-Checked Cam timing
-Checked with Boost controller disconnected
-Checked the waste gate.
Only thing left is to change the waste gate and use a 1.5 bar spring.
Please advise.
Thanks.
Old Mar 18, 2017 | 12:13 PM
detroit pistins's Avatar
At what psi did you check for boost leaks?
Has this issue recently started occurring or after a modification you had done? if so, what was it?
Can you post some pics of the engine bay and parts setups?
Old Mar 19, 2017 | 05:42 AM
mines5's Avatar
Checked boost leak at 36psi.
this happened after I changed my exhaust manifold and waste gate. . Wasgate is turbodmart comp gate 40 38mm. With 2 -7 psi springs.
Old Mar 19, 2017 | 07:44 PM
is your wastegate external or recirculating? if external, check if it is leaking exhaust gases at idle so you know if it is not sealing properly.
Old Mar 19, 2017 | 11:20 PM
mines5's Avatar
It's external . Non recirculating. How can we check if its leaking at idle?
Old Mar 19, 2017 | 11:24 PM
mines5's Avatar
Old Mar 20, 2017 | 01:27 PM
XSivPSI's Avatar
You're head is extremely dirty around the exhaust manifold flange. Maybe its leaking there really badly.
EDIT: Well it looks like everything is extremely dirty and you said you checked that so never mind.
Old Mar 21, 2017 | 03:11 AM
mines5's Avatar
It's actually clean, it gets more dirty here.
any one faced a similar issue?
Old Mar 21, 2017 | 04:42 AM
AWD96's Avatar
Put a TiAL MVS 38mm on it and see what happens. Anyone local you can swap and try for a quick minute?
Old Mar 21, 2017 | 06:26 AM
mines5's Avatar
Tried tial mvs 38mm. Flange is same but it wont fit. It's head is bigger touches power steering pump and lines
Old Mar 21, 2017 | 06:30 AM
mines5's Avatar
Can't find another tsmart 38mm.
looking to swap exhaust manifold. Wgate down pipe. If that disnt work either then the last option left is to change the cylinder head but that would be the end of this chapter. Extremely frustrated.
DCD
Apr 24, 2008 04:06 PM
Deezee
17
Mar 30, 2007 08:21 AM
crasher
10
Mar 8, 2007 10:22 AM
SA_Evo
Mar 13, 2006 12:05 PM
PHiSH
14
Aug 26, 2004 03:09 PM
