Stock Block FP Red (SS) Kelford 272 93oct 28psi (3port vs MBC comparison inside)
Old Nov 16, 2017 | 05:47 AM
  #31
hatersGONNAhate's Avatar
Last pull of the year. 40* day
Old Aug 6, 2018 | 03:06 PM
  #32
Rob_STI_PNW's Avatar
Literally mirror image of what my car is
Cept mine doesnt feel like it's 'pulling' until 5500~, pretty sure Im full spool (24 psi currently) around the same time the OP car is
Old Sep 6, 2018 | 07:16 AM
  #33
gqcode's Avatar
Veteran: Air Force
Originally Posted by hatersGONNAhate
Recently put the car on e85. Stock block 138k
Mods stayed the same other then fuel upgrades, which includes
Fuel lab regulator
Walbro 450 rewired
Drilled siphon
FID2000cc
I was the only person in the car at the time of tune!!
Car trapped 132mph
That I believe but the Stock block FP Red SS and Kelford 272 93 oct chart is crazy! It almost look like my dyno chart on E-85. I have done a lots research and to make over 500whp on pump gas on a FP RED I thought was almost impossible! What is it that I'm missing? I don't understand, my dyno chart it VD https://www.evolutionm.net/forums/ev...uel-e70-3.html . All the help is welcome I know he got ported and polish manifold that is the only difference that I see. Let me know
Old Sep 7, 2018 | 04:55 AM
  #34
144k miles on stock block 10s
Old Sep 7, 2018 | 05:25 AM
  #35
gqcode's Avatar
Veteran: Air Force
Congra on that run, what is your setup? I just can shift fast enough but I working on it and need tire my best time this year 12.4 at 120mph 60ft 1.7
Just asking for your opinion, think you make over 500whp on FP red like the 93 oct dyno chart with that mod list?
Old Sep 10, 2018 | 04:34 PM
  #36
2006EvoIXer's Avatar
Originally Posted by Eric SlowEvo8
I make 564 e85 2.4 on maf that's how the car came ill be going sd soon with 4 inch ic and spool up and see how we do unless red sells I'm going bigger
In SoCal, I'm expecting 550ish from a Red running in its efficiency range. With E85 properties, we can push it out of its efficiency range a bit. But I can't see 600+ whp being safe long-term (strictly my opinion)
Old Sep 11, 2018 | 04:08 AM
  #37
Going on a year now, near 600 and 2.5 over 500. Torque is controlled very well to help the stock bottom end
Old Sep 26, 2018 | 06:20 PM
  #38
gqcode's Avatar
Veteran: Air Force
Are you E85 or 93 oct. this tread is saying over 500whp on 93 oct
Old Sep 27, 2018 | 03:54 AM
  #39
i did make over 500 virtual dyno/dynojet on 93. Car is currently on e85 now tho
tscompusa
Sep 1, 2016 05:00 PM
tscompusa
Feb 24, 2015 01:20 PM
tscompusa
Jan 20, 2014 08:00 PM
tscompusa
Evo X Dyno Results
12
Sep 16, 2013 09:55 PM
tscompusa2
May 8, 2011 09:10 AM
