OFFICIAL: Track videos thread [MERGED]
Track video thread. Please post videos using the following format:
Track: (Track Name)
Lap time:
Car:
Mods: (Mod summary, power level, tires etc.)
Notes/Comments:
Video: Video URL/embed
Track: Buttonwillow CW #13
Lap time: 2:14.XX
Car: Evo IX
Mods: Street tires, 3" TBE, Tune & Bilstein/Swifts
Notes/Comments: Best recorded lap of the day.
Here is some feedback from a friend that used to run an evo in race events:
Lap time: 2:14.XX
Car: Evo IX
- You need to pick up the throttle much earlier. The ACD in the Evo only works in your favor when you're on the throttle, so you need to get all of your braking done in a straight line and accelerate through the apex to the exit. There are a number of corners where you are waiting for the front tires to bite to get back on the throttle, but you're not using the differentials to your benefit by doing that. The way the maps work on the ACD, the car will basically behave like a FWD car until you add throttle, and then you get more and more lock in the center diff as you feed in the gas. Do it early enough in the corner and you should feel a nice 4-wheel drift on the exit of sunrise and sunset.
- Don't be afraid to turn the car in hard and get on the gas. In the tighter corners (like cotton corners), you can turn in aggressively -- which will upset the car and make it change direction -- and then get on the gas to drive it through the apex. The way I would go through that section is an aggressive lift/steer/gas/lift/steer/gas. Don't be afraid to make the car move around a lot in the tight stuff. That's what it's designed to do.
- On long sweepers (like the sweeper leading into the esses) you may want to try hugging the inside line and managing the throttle instead of a traditional late apex. Depending upon how your car is set-up and the tires you are on, that at times can be a lot faster in the Evo.
Power - 291whp/300tq
Suspension - MR Bilstein/Swift Spec-R springs, Whiteline RCK
Tires - Dunlop Z1 Star Specs
Brakes - EBC Orangestuff (F/R), DBA 5000 Rotors(F), OEM Rotors(R), Stainless steel lines, ATE Super Blue fluid, Girodisc titanium shims
Stock aero, beatrush undertray
This is my fourth time at Buttonwillow and second time running this configuration.
I don't have ***** big enough (or track insurance) to run my car at Infineon Raceway or any other track that doesn't have enough room to let me make mistakes as part of the learning curve.
See: https://www.evolutionm.net/forums/mo...ing-track.html
With your power and suspension you can still shave off a good chunk of time, I would say at least 7 seconds. You can be much more aggressive everywhere and definitely be more aggressive through cotton corners. After the apex of Riverside you should track out to hold more speed and then come right to enter sunset. There's plenty more, but you can go faster everywhere on that track.
Rode a lap w/you. Nice job
Be great to get you a bit further south & east at Fontana one day
Again, Nicely done!!!
Joe
EDIT: If you want to see some EVO lap times click the link. Scroll down to approx mid page
http://www.socalevo.net/index.php?op...topic=118629.0
Joe
Careful with the pitfalls on the Evo. Like bullet 2. Yes, you can claw your way though a turn with AWD helping out. I drive to smooth out transissions and carry momentum. Going too aggressive can overslow the car and upset the handling.
Agree on 1 and 3. Get on throttle before apex. Track out WOT.
Petpev of mine Two hands on the wheel unless shifting. On the short straights you have a tendency to hold the shifter. Wheel, shift, back to wheel.
Mind curbs. Some can be driven over or right on. Some will wreck suspension parts. That hump you hit looked like it upset the car a good amount. In the esses - how agressive are they? I'd be damn tempted to run a straight line there and bounce off Supercar v8 stly'n.
Use that throttle to steer the car. Wheel input should be relatively static for the long sweepers. You can adjust a hair in/out on the gas at that point to add or remove rotation.
You live in Socal or Norcal? Who tunes your car, and on what dyno did it make that 291/300? 9 turbo?
Sounds like youre relatively new so youre doing a good job of driving within your comfort zone. Here are a few things you can work on. More gas pedal just about everywhere. You missed just about every apex. A few times you were driving with 1 hand way too long. And work on your heel-toe, it doesnt sound good. Now some general feedback turn by turn.
- Sunrise: You missed your apex, you were late on the gas, and you didnt track all the way out. When you carry more speed youll naturally slide all the way out.
- Buttonhook: Missed your apex and then too much 1 hand driving after.
- Cotton corners: Dont know if you were frazzled by the car that was off, but you turned in way too late and totally missed your first apex.
- Club corner to bus stop: More gas.
- Bus stop: You ruined it and lost lots of speed. You need to be on the gas before you apex and carry all that speed to Riverside.
- Riverside: Your line was pretty much perfect and you actually hit your apex.
- Phil hill: Missed your apex and need more gas.
- Sweeper: Its a double apex, so you totally missed the 1st one. Start out far left like you were but turn in much earlier as you trailbrake clipping the first apex. Track out far left then gradually turn in for the 2nd apex. And more gas while youre aiming for it.
- Short straight after esses: Too much 1 hand driving again.
- Sunset: You missed your apex a little, not enough gas after, and didnt track out all the way.
I've been running my evo for about two years total and I'm just starting to get the car to a point where I'm pushing it more than 7/10ths. I'll take another look at my line and the turn apexes to see how much I missed them.
I agree, I did do a lot of one handed driving. That will have to stop.
Edited.
My car was tuned by Andy Chan @ Speed Element back when they were tuning cars. In fact, my car was the last car he tuned before he left Speed Element and went back to school.
Dyno Dynamics Dynamometer
Stock IX turbo
3" TBE
Drop in filter
