SST Transmission Downshift
Hi Guys,
I purchased a Ralliart 2010 the other day and have realised something with the Transmission.
When i am driving in D normal mode and when i am in 5th gear and wanting to slow down to come to a complete stop, i can sometimes hear the transmission downshift to 4th gear. This only happens sometimes and does not happen when in manual mode or sport mode. This does not even happen when i am in 5th gear and step on the pedal a little to go faster and the gearbox downshifts to 4th by itself.
Only happens when i want to slow down and comes to a complete stop.
Is this normal with these transmissions or should i get it checked out.
Hearing or feeling a shift from this transmission is usually nothing to be alarmed about. It can often be irregular, intermittent, and sometimes happens once and then never again.
As hard as it is for many people to hear, the best advice is to monitor the car's behavior, and not so much the noises. It can be annoying and worrisome, to the point where people get rid of the car for fear of problems, but the majority of the time it's just the SST giving you a piece of its mind.
If the car starts behaving differently or it becomes regular and progressively worse, then maybe would be the time to get it looked at.
At the very least, though, since you just bought the car I also would support the recommendation that you change the fluid and filter with new OEM parts, if for nothing more than peace of mind. A few hundred spent in maintenance is much better than a few thousand spent on repairs, imo.
Hi Guys,
I reccomend NEVER driving in Normal mode, always Switch to “SPORT” and shift Manually either with paddles or pushing up or down on the shifter.
Drive the car as if it were a full manual that you do not have to “Clutch” yourself. When downshifting and Stop and Go this will save your clutches because in Normal mode it allows more slippage to “make is smoother” like an Auto.
Alot of people drive their Ralliart or ME with the SST in Normal mode and this results in premature failure in the trans causing very costly repairs!!
Hi Guys,
Manually selecting which gear you should/Want to be in in SPORT mode will “Beep” at you if the car just made that shift for you because you were “Too late” to shift up or like I mentioned, if you are slowly down, or stopping very quickly it will jump down up to 2 gears at a time to be sure you are in the correct gear for how fast you are going and based on speed and if brake is being applied, preventing damage and hard shifting.
When accelerating and shifting thru gears very quickly when in SPORT mode as well it is reccomended you do not lift off the gas and the shifts will be faster and smoother as well, as the computer controller is constantly trying to guess if you are trying to accerate fast, let off the gas to slow a bit (say around a turn) or if you may be starting to slow down and down-shift again.
Hope all this info helps, LOL
pckiller00
Aug 15, 2015 12:21 PM
moody91180
Mitsubishi TC-SST Discussion
Oct 11, 2014 06:22 PM
SmurfZilla
13
Oct 6, 2012 01:29 PM
