S2K to Evo cluster swap
This thread is outdated and long.
Here's my quick and to the point guide on this swap.
https://www.evolutionm.net/forums/ev...l#post11771172
How's it going everyone, I'm new to evom.
Sorry if this is in the wrong section, tried finding the correct one haha.
Anyways, I more or less joined just so I would have a place to upload this info for later reference, because I kinda suck at keeping up with info/pictures on my phone.
I'll be uploading pictures/info as I go through this project.
I'll be starting off with an S2K AP1 cluster and harness.
For now, just waiting on parts to deliver.
Bought a chopped gauge cluster harness off an Evo 8 parts car.
No way I'd chop into my personal one just yet lol.
Yeah. I've personally never been a huge fan of the OEM cluster.
Some people love the S2K cluster <me.
Some hate it, lol.
Either way. Wanted to try something different.
Some hate it, lol.
Yeah
I physically have everything I should need.
The main thing to overcome here is going to be calibrating the tachometer, speedometer, coolant temp, and fuel level.
I've researched just about every S2K cluster swap thread out there ranging from Honda Accord forums, to 2g DSM forums.
Pretty sure I can use the K-tuned S2K dash converter to adjust the cluster to where it'll need to be.
This supposedly adjusts Speed, coolant temp, and fuel level via a USB connection and computer software availible from K-tuned.
After that It's just fitting the new cluster into the dash in a fashionable way...
Tried reaching out to an Australian cluster company for one of their cluster blanks...however they're pretty pricey...guess I'll be making my own.
That comes out to about $520 USD right?
What I may actually do instead is make that insert from a spare cluster shroud instead.
Like this.
ALSO.
Would anyone be able to pull a wiring diagram for the gauge cluster harness for me?
I've been searching around and haven't found one yet.
I already have an S2k diagram.
No idea why this uploaded as a GIF.
Quick update.
The majority of the harness wiring I'll need came in the mail a couple days ago. Haven't had time to start on it with me being busy with training.
However I did manage to gather some excellent wiring diagrams for the S2K AP1 cluster.
AP1 diagram, color coded
Ha, me too. Just now started opening up the cluster.
I may or may not change the color template. If I do I'd probably need to do an LED swap on the cluster to get a nice color out of it...since the bulbs in it burn orange/yellow.
oh well. Just gonna focus on getting it working first.
If you do attempt this, be careful taking off the white cover. It's pretty thin and the tabs will break very easily.
Working out what wires we'll be needing to keep, and what wires to cap off.
There's 41 wires to the S2K (AP1) cluster versus 30 to the Evo 8 cluster...
If somebody happens to have a color coded Evo cluster harness you'd be my saviour right about now.
struggling to find one. Once I get to the evo harness I'll make a list of what wires go where between the S2K/Evo harnesses.
updated this information.
Okay so here's the correct information for an Evo 8 WITH an ACD wiring harness.
C-106 (White Connector)
1 BLK...........Ground 3
2 BLK...........Ground 3
3 BLU/GRN.......Left Turn Signal (+)
4 RED/WHT.......High Beam (+)
5 BLK...........High Beam (-)
7 RED/BLK.......J/C 1 (+) (10AMP FUSED)
8 YEL...........Door (+)
Ignition
9 YEL/RED.......Charge (+)
10 GRN/WHT......Tarmac (-)
11 GRN..........ECU/Tach Input
12 WHT/BLK......Speedometer Input
13 GRN/ORG......ABS
14 PNK..........Gravel (-)
15 VLT..........Snow (-)
16
17 WHT/BLU......Check Engine (-)
18 WHT..........Oil (-)
19 RED..........Charge (-)
20 BLU..........Fog (+)
21
C-108 (Blue Connector)
31
32 BRN..........Brake (-)
33 VLT..........Water Spray (-)
34 BLU..........Door (-)
35 RED..........Seat Belt (-)
36 GRN/YEL......Air Bag (-)
37 BLU/GRN......Brake (+)
Positive Lead
38 GRY..........General (+)
39
Negative Lead/Rheostat
40 BLK/YEL......J/C 3 (-)
41
42
43
44
45
46
47
48 BLK..........(-)
Fog (-)
Turn Signal (-)
49 PNK..........Right Turn Signal (+)
50 YEL..........Water Temp Input
51 GRN..........Fuel Gauge Input
Fog Light Switch
3 - Black Yellow - From Rheostat
4 - Green White + From fuse box 7.5a
Hazard Warning Light Switch
3 - Green White + From fuse box 7.5a
4 - Black Yellow - From Rheostat
Ignition
13 GRN/ORG......ABS
16
21
31
Positive Lead
39
41
42
43
44
45
46
47
48 BLK..........(-)
Fog (-)
Turn Signal (-)
Fog Light Switch
