Transmission fluid
Old Jul 26, 2017, 06:13 PM
Lucas Mendoza's Avatar
Transmission fluid
Was thinking of flushing and changing my transmission fluid in my 06 ralliart just had a couple questions on what is the best fluid i should use thanks.
Old Jul 26, 2017, 09:10 PM
4b11slayer's Avatar
Factory.
Old Jul 26, 2017, 09:19 PM
Should say in my owners manual right?
Old Jul 26, 2017, 09:46 PM
4b11slayer's Avatar
Diaqueen sp3 if im not mistaken.
Old Jul 27, 2017, 07:20 AM
Is it an easy diy thing to do? Just common handtoolw right? Nothing extreme
Old Jul 27, 2017, 09:50 AM
4b11slayer's Avatar
Yea just hand tools.
It should be a 15/16 or 24mm wrench to drain. I could be wrong.
You can drain it and measure how many quarts you drianed so you can fill it back in with exactly what you removed.
Or start with 2.5 quarts, start engine, let it get to operating temp, switch the transmission through the available gears. I.e go from park to reverse.drive.neutral.drive.shiftronic.
While in the different gear positions leave shifter for 5 seconds in each position.
Shift back to park and check level. If level is low add fluid accordingly and repeat the Gear position preocedure.
Note: If adding fluid and not moving through the gears you will get a HIGH inaccurate level.
Old Jul 27, 2017, 06:58 PM
Thanks a lot appreciate the help!
Old Jul 28, 2017, 08:39 AM
slc-ralliart's Avatar
BG Synchroshift II works fantastic in 04-06 Ralliarts. Amsoil/Redline is great as well.
Old Aug 6, 2017, 08:06 PM
cmartin2112's Avatar
I just ordered 3qts of the Redline MT-90 for mine... if you want I can let you know how it goes...
Old Aug 7, 2017, 09:13 AM
Definitely let me know how it goes
Old Aug 7, 2017, 10:52 AM
RalliartN's Avatar
Factory Mitsu oil. Read this: https://www.jackstransmissions.com/pages/oil
Old Aug 11, 2017, 06:32 PM
CrAnSwIcK's Avatar
this is true...
however if you choose to use aftermarket oil, don't use amsoil
I've had good results with redline...
Old Aug 18, 2017, 03:21 PM
Will do. Just got my order today... Shipping took forever...
I'll knock it out this weekend and update your thread!
Originally Posted by CrAnSwIcK
this is true...
Glad you still support Redline! I made my purchase based of a few older threads I read which you and a couple others recommended it.
Old Aug 22, 2017, 07:01 PM
Got a chance to do the change on Sunday and overall I can say there was defiantly a positive change! I still have a few issues that I was hoping would go away w/ fluid change but they stuck around unfortunately... However I would still recommend doing the job and using that particular fluid.
EvilDSM97
Jul 16, 2016 06:10 PM
Blue Evo 8
12
Mar 4, 2013 11:13 PM
a2b
Nov 14, 2012 12:33 PM
Freddie1111
Nov 23, 2004 11:44 AM
Quick Reply: Transmission fluid
