Silverflyer Evo 9 FP green 73HTZ MHI S2 cams results
Old Dec 21, 2017, 01:09 PM
silverflyer's Avatar
Thumbs up Silverflyer Evo 9 FP green 73HTZ MHI S2 cams results
Evo IX
Stock block
FP Green HTZ 84mm MHI (FP Ported)
FP race manifold (Curt Brown Ported)
GSC S2 cams with 5040 springs
Stock head - refreshed with a valve job
FIC 1650cc HighZ injectors (resister bypass)
TSCOMP Double pumper with pressure switch for second pump (two walblo 255s)
boomba fuel rail with stock FPR and lines
Buschur TBE with high flow cat and large magnaflow muffler
Invidia 02 housing
Buschur FMIC/LICP/UICP
Stock IM and TB (Curt Brown Ported) (MilSpec High Pressure Throttle Shaft Seals/Rebuild)
Spoolinup COP
Tial QR
Grimmspeed 3-port EBCS
Stock ECU with speed density tuned by TSCOMPTUNED
More pictures and updates on my build thread:
https://www.evolutionm.net/forums/pr...-ix-build.html
449hp 362tq on 93 Octane pump gas. TSCOMP Virtual Dyno.
Old Dec 21, 2017, 02:30 PM
Klaiceps's Avatar
Oh damn that's good for an FP Green on pump gas. Very nice numbers! Is the HTZ really that large? Any plans for an E85 tune?
Old Dec 21, 2017, 02:50 PM
From what I researched the new HTZ compressor flows close/the same as the original FP Red with no loss in spool from the original green. I'm glad I had FP upgrade the compressor when I had it rebuilt.
E85 coming in the Spring/Summer 2018. I think we only have E70 winter blend available in Illinois right now. I have to go and test a batch to find out.
Old Dec 21, 2017, 03:27 PM
e_kobz's Avatar
Solid numbers. E85 will be a nice jump in power. Curious what spring you’re running on the TiAL QR?
Old Dec 21, 2017, 04:41 PM
Klaiceps's Avatar
Your spool definitely looks in line with the old green which is really a plus. Did you get the Xona rotor bb housing also?
So safe to assume the new Red will flow more than the old one while keeping the same spool as the old red? Gosh I hope so.
Old Dec 21, 2017, 06:18 PM
The QR has the white spring in it and a dedicated 1/4 vacuum line going to it from the intake manifold. It works flawlessly and sounds great!
The exhaust is super quiet for an Evo. All you hear is the turbo spool and then the car just pulls. It's a true joy to drive.
Journal bearing with the aero nut option. It was converted/rebuilt from a stock cover 73HTA. Pictures in my build thread.
The FP red looks nice to, but I've wanted to try out the green for years now. The green has a great powerband for the street on a stock 2.0L.
When I build the engine I think I will change my setup to an FP black MHI and 2.3L stroker.
Old Dec 21, 2017, 06:26 PM
Klaiceps's Avatar
Thanks for the insight on the HTZ Green. I keep going back and forth between this and the red and I am still having a hard time deciding. Your E85 results will be my deciding factor. I'll check out your build thread.
Old Dec 23, 2017, 10:53 AM
Dakota Evo's Avatar
Its spooling pretty well for single scroll but an mhi housing green be at peak at under 4000 rpm.
Thing spools a little better than red and makes power like red.
Old Dec 23, 2017, 04:27 PM
dookgvr4's Avatar
From what I understood this is a MHI Twinscroll housing
Nice car and results
Hopefully Tom can work his magic for me
Old Dec 23, 2017, 04:33 PM
kaj
kaj's Avatar
His turbo is an MHI housing.
Old Dec 24, 2017, 10:17 AM
Dakota Evo's Avatar
sheeit buttload of power then.....amazed
id trade 300 rpm of spool for 50 whp......
Old Dec 25, 2017, 07:04 AM
Steveevo9's Avatar
Beautiful car & great mods, I like the power/torque that you've achieved. Nice job to Tom as well.
Old Dec 27, 2017, 05:38 AM
jeewee804's Avatar
Everything is so clean, Dope results!
Old Feb 20, 2018, 07:48 PM
EvO IX 51o's Avatar
is your fp green a jb or bb?
Old Jul 15, 2018, 07:38 PM
Journal Bearing
Quick Reply: Silverflyer Evo 9 FP green 73HTZ MHI S2 cams results
