oil smells of gas
Old Jul 19, 2018, 09:05 PM
Jonno99's Avatar
oil smells of gas
ok I always put fresh oil in before every track session but I notice when I get home the oil smells of petrol, it looks ok on the dip stick but I was wondering because this oil isn't cheap ok, do you think its ok to leave it in till the next track day before I change it, usually about 6 weeks. I only use it once ever couple of weeks on the weekend.
Old Jul 19, 2018, 09:26 PM
2006EvoIXer's Avatar
You have enough blowby through the piston rings that fuel vapor gets into oil. Do you have a good crankcase ventilation system? If not, make one to reduce the oil contamination.
Did you run engine with no boost for long cool down after track? With a good crankcase ventilation system, running long period with no boost will help oil evaporate fuel to reduce contamination.
Old Jul 20, 2018, 03:08 AM
Jonno99's Avatar
got it, i thought that was all for higher tuned cars, I'm only pushing 330hp
Old Jul 20, 2018, 04:20 AM
330 isn't much. You may want to do a compression when you get a chance (just in case).
Old Jul 20, 2018, 06:13 AM
Richard B's Avatar
A compression test is good. But a cylinder leak down test will tell you where your gasses are escaping to. It’s best to do both on a warm engine that way the piston rings are expanded and lubricated like they would be under driving situations. While performing the leak down test if you take off the oil fill cap and hear an air wooshing sound you know that your rings are bad.
Old Jul 20, 2018, 07:57 AM
Crankcase ventilation will help. Your car may make "only" 330whp, but that's almost 100hp more than stock. Add in hot lapping with a lot of WOT and high rpm and it just compounds it.
I know they're not "local" for you, but STM's sealed catch can is really the easy button option for a good catchcan/vent setup. You can order that, or copy it's design..
Old Jul 20, 2018, 10:28 PM
Jonno99's Avatar
thanks mate, wow thats a 449 USD buy, dual or single port?
Old Jul 21, 2018, 12:26 AM
I would do the single. It's worked well on several cars I've put it in. The dual port adds a breather to the front balance shaft inspection port, and a lot of oil can come out of there.
$450 seems steep at first, but the value is there with the parts it comes with.
Old Jul 30, 2018, 10:09 PM
wfo944's Avatar
a good blowby kit is a great investment
supercharged
25
Dec 16, 2014 10:43 PM
Jasoob
Apr 19, 2012 02:22 PM
nem187
Mar 12, 2009 01:52 PM
cplise
Feb 20, 2009 05:20 AM
nytejade
Feb 2, 2009 12:26 PM
Quick Reply: oil smells of gas
