CA Evo 8 Build
Old Nov 13, 2018, 01:47 PM
truitt's Avatar
CA Evo 8 Build
Hello,
I am planning to set my Evo up for a beefed up Daily Driver with a conservative tune for the 400-430 hp range on E85.
Here is what I got so far
Installed
Megan Downpipe
Catback Exhaust
MAP Intake
What I have to install
Ported OEM Manifold
Ported HTA71 Turbo
MAP Hood O2 Dump
Test pipe
Grimspeed 3 port BC
AEM Wideband
Walbro 255
FIC 1220 cc injectors
http://fuelinjectorclinic.com/mitsub...1-9/IS126-1220
GSC S2 Cams
ACT XT Clutch Kit
ACT Streetlite Flywheel
ARP Flywheel Bolt
All new exhaust gaskets, new rear main seal when replacing clutch. New O-rings for injectors.
Is there anything else I am going to need or should purchase? Doing all of these after I replace my clutch and flywheel. Cars been down for a couple weeks after clutch went out, also bought redline cocktail for tranny flush and diaqueen for trasnfer case\Diff.
Old Nov 13, 2018, 01:54 PM
Almost an identical set up to mine except i have a 9.
Have done all that you noted except for the ported mani / O2 setup. DynoJet no.s were 459/400
Your list looks good to me
Old Nov 13, 2018, 07:19 PM
truitt's Avatar
Thank you, just making sure because it’s very easy to get carried away sometimes when everything is apart/down.
Old Nov 13, 2018, 07:34 PM
Totally understand. I recently added the S2's & the HTA71 but i should have done the O2 housing as well
But, all in all, the EvO is running super well & just love the cams.
Hey, when you get tuned, post up in the Dyno Results forum so we can see how ya did
Old Nov 13, 2018, 07:36 PM
2006EvoIXer's Avatar
Personally, I'd orefer HFC over test pipe. But it costs 10-15 whp to be environmentally friendlier. Lol
How are you planning to port your manifold and turbine housing? What about intercooler and pipes (especially the lower intercooler pipe)?
Also, don't forget to upgrade valve springs and retainers with S2 cams.
Old Nov 13, 2018, 07:40 PM
I have an O2 housing with your name on it. You just need to decide when. Lol
Old Nov 13, 2018, 08:22 PM
Biggiesacks's Avatar
I would add an evo x map sensor, so you can log and control boost directly through the stock ecu. An omni 4-bar is also an option but with your goals you shouldn't need it. Also +1 on at least a Lower intercooler pipe, the stocker is very restrictive.
Old Nov 13, 2018, 08:34 PM
Check out my custom LICP made for oem intercooler.
Old Nov 13, 2018, 10:12 PM
truitt's Avatar
I bought the mani and turbo already ported. I forgot to list my IC stuff. I have a Godspeed 4 inch intercooler with injecn uicp and licp
Old Nov 13, 2018, 10:47 PM
Wow, 4" Is overkill for 71hta. Lol
Old Nov 13, 2018, 10:51 PM
One more thing. Check your throttle body seals for boost leak.
Old Nov 18, 2018, 11:45 PM
Wicked_X's Avatar
Injen LICP is pretty restrictive. Might want to pickup an ETS or something different. I did and was surprised at how tiny one of the bends is compared to the ETS one. Stoked to see your results, I've got a similar setup I'm putting together soon! But I'll be on stock cams. How much boost do you plan on running?
Old Nov 19, 2018, 01:39 AM
Wicked_X's Avatar
Also, I dont think the Injen UICP will fit with any intake besides the Injen one. They have their own BOV location made for each other.
